Re: 24 analog inputs on an HD I/O?
OK, I just reread Mikes post and I did miss read it but Mike is wrong that an ADAT bridge would be 32 IO of analog
the ADAT bridge would need AD and DA converters hung off of them one could hang a pair of 888|24s off the legacy port for analog IO but the legacy port can be temperamental
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I've been doing it since I got Radar which is 6-8 years ago. 32ch I/O with a single 192.
Maybe there's something wrong with mine. |
So for any confused new folks, HD IO is 16 inputs and 16 outputs max. You stick another one on a digilink chain and get another 16 inputs and 16 outputs. And a digilink cable has an total of 32 inputs and 32 outputs max. (so for example if you want 64 input on a MADI IO for it takes two primary digilink connections). Darryl |
YES
If you utilize the legacy port you will Have up to 32 IO per each 192 The legacy port disables the digilink expansion port So it kills a second 192 or 96 attached to a expansion port So with the legacy port it is possible to have 32 IO with 1 digilink cable Legacy port > digi8 "y" cable > 2 888/24 = 32 inputs 32 outputs @ A Max of 48k
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
Analog 5-8 Inputs on 002 | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-07-2006 08:24 PM |
8 More Analog inputs in 96 i/o? | Robby Hamilton | Pro Tools TDM Systems (Mac) | 1 | 08-25-2002 10:45 AM |
Help, analog 3/4 inputs gone! | Frost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-28-2002 06:37 AM |
?Need more analog inputs? | Jahmontee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-02-2000 10:58 PM |
