Old 11-14-2013, 11:10 AM
marmouch273 marmouch273 is offline
Default Pb leds on d-command main units
I use a D-command on my studio and have some troubleshouting since a short circuit has occured today.
The leds have began to flash, so I reboot the two units, then the short circuit has occured and since all the leds doesn't light anymore on the main unit but still work on the fader pack.
I've tried to adjust the brightness and the contraste but still no leds.
Reset the firmware didn't change anything.
Tried all leds test (vegas, yellow...)but no bargraph or any led's works.
However, the faders still work.
Is this a problem with the led power supplie?
How can I fix this? Do I have to change the led PSU?
How do I do that?
How much it will cost?
Thx for your answers.
Regards.
Old 11-14-2013, 11:25 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pb leds on d-command main units
Originally Posted by marmouch273 View Post
How do I do that?
Regards.
I would imagine there would be a feed from the main power board to the LED controller board, so likely it has blown something on the power feed to the LED board.
You will need to get an electronics expert to check the power supply and all power feeds for continuity and voltage.
You could take apart and check the power supply for visual issues and see if there are any noticeably blown/brown components or a fuse thats blown etc.
You might get lucky but i expect it will need an expert to diagnose and fix.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 11-20-2013, 03:01 AM
marmouche marmouche is offline
Ok, do you know where I can find such an expert in France?
I beter have to contact an Avid professionel don't I?
Could you give me any link or number?
Thx !
WTB: Avid D-Command ES, Main unit dicky.chan Buy & Sell 2 08-15-2013 02:48 PM
D-Command main unit and X-mon Stylin' Audio Buy & Sell 4 10-27-2012 03:14 AM
D-command main unit won't boot mark linett ICON & C|24 5 08-20-2011 07:35 AM
D-command main + Fader not loading atlantistudios ICON & C|24 3 09-09-2010 08:02 PM
D-Command leds blinking while writing automation?? ARTHANOR Productions ICON & C|24 1 11-22-2006 12:55 AM
