Hooking v-drums up to Strike?
After using Strike for a while I can now safely say i'm completely over real drums, setting them up, micing them up and sorting placement, conditioning the room sound, tracking them, and all the rest... especially considering i end up sound replacing most of the hits anyway to get that 'metal' sound.
I've now got a session drummer on board that also has a Roland V-Drum kit, so i'm keen to throw real drums to the curb and work out how to get this new alternative up and pumping. Before I get him to bring the kit in, i'm wanting a 'connecting v-drums 101' so we can hit the ground running. Can anyone tell me the process of getting v-drums into Strike and heard thru my monitors? Any pointers are much appreciated |
Re: Hooking v-drums up to Strike?
Unless something has changed recently with the way Roland does the hi hat on the v-drum, it is going to be a challenge for you. The V-drums HH are not mapped F#1 (closed), A#1 (open). It's a continuous controller thing so there is complete variation from tight closed to full open. There are some software drum products out there that properly map the V-drums. I'm pretty sure Strike is not one of them.
Busch. |
Here's a nice little video that shows Ocean Way drums mapped to the V-Drum Hit Hat. It give you a good idea of the complexity of sound you're dealing with.
http://www.youtube.com/watch?v=uS0-29tyT-A Busch. |
I am very interested if you have any success with the vdrums and Strike. I am going to pick up the VI either way, but would really dig it if I could use the kit with it.
I use the TD20bk kit in our studio. I recently started using strike but as with the td20 kit I have recorded midi and then used the 8 outputs from the TD20.
What I found really cool is to record the midi then break it out and play it back through the TD20 to isolate and adjust each piece of the drum kit.
James Shelby SRS Labs Aurora, Colorado |
So I need to sort out the different zones on the hi-hats (and cymbals in general i'm guessing). I'm guessing I need to map this prior to tracking or the hat hit information will be simplified to one channel - is that what'll happen? Or can I adjust this after the fact during mixdown?
Strike for E-Drums? | jglover51 | The Drum Room | 1 | 08-31-2011 09:17 PM |
Anyone using Strike with V-drums | Wayne Dawkins | Virtual Instruments | 2 | 08-22-2010 08:48 PM |
Hooking Strike up to a Behringer FCB 1010 As A Footcontroller | doppler58 | The Drum Room | 3 | 02-18-2010 02:10 AM |
can i use my v-drums with strike? | music project | Virtual Instruments | 6 | 11-29-2006 08:31 PM |
How To Set Up Strike With V-Drums | ChaplainPC | Virtual Instruments | 1 | 10-18-2006 06:33 AM |
