Revibe 5.1 protools ultimate
Hi
Since we've installed the last protools version, i can no longer hear the reverb on the center when i use a revibe 5.1, only some weird E/R without any tail. Still can tweak the front and rear side but i have to load the same verb in mono on an other aux to have center... It's like the a quad verb now :/ Wasn't the case on previous version so wonder why 5.1 verb is no longer a 5.1 verb (maybe there is on option to check or something ?) Thx for your answer |
Re: Revibe 5.1 protools ultimate
In the "Levels" section, make sure "Center" is turned up (it's -inf as default).
YEah it is for sure
When I turn it up ain't got any reverb just e/r like I said, it's really weird :/ |
Any other idea ?! Using a lot this verb and it make me lose a lot of time
I'm not seeing the same issues here, al is working fine.
What version of Revibe are you running? Mine is 18.1 (and PT 2019.5) |
Thx farhoof for your concerne
Using protools ultimate 2018.7.0 and revibe 18.1.0.1441 (😬?!) |
A while ago we encountered this issue as well and found it the newer version/versions of RevibeII had this problem, while the older version worked fine. So I assume the issue hasn't been resolved yet.
I'm not at work, otherwise I could have looked up the correct working version, but maybe you can find a previous installer of the plug-ins. I think the correct one was before or in the early PT2018 versions. If you aren't able to find a working one I can search the right one for you next week. |
Hi frits
Would be great if you could find the good version that works well Would allow me to save a lot of time ! Thx by advance ! |
installed via the avid plugin bundle (I don't see it on the revibe download page). |
Protools Ultimate 2018.7 + Maschine | day_tripper | Pro Tools 2018 | 5 | 01-10-2019 07:47 PM |
windows 10 protools ultimate bug | stanonbass | Pro Tools 2018 | 1 | 05-07-2018 06:28 PM |
ProTools 12 Ultimate - CPU Overload without playing | Aquic | Pro Tools 2018 | 38 | 04-25-2018 07:05 AM |
protools hd native 10.3.9 and Revibe | Cryos | Pro Tools HDX & HD Native Systems (Mac) | 0 | 01-23-2015 07:06 PM |
Revibe on Protools HD 7.0 | Magno | Pro Tools TDM Systems (Mac) | 2 | 11-07-2005 06:15 AM |
