Are you still mixing in the box on a S6?
Just curious of those who were mixing in the box on an Icon and are now using more of the control surface on the S6. I'm new to the S6 and so far I haven't changed my mixing from mostly in the box. If you have changed, what do like better on the S6 control surface? Thanks.
Re: Are you stil mixing in the box on a S6?
100% in the box here. Instant total recall is a must for my work. And besides, after working for many years on analog consoles and still having a passive summing box and excellent pre-amps, I have concluded through my tests that in the box sounds better.
As far as Icon vs S6, sorry can't comment on that except to say that I love the S6!
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
Re: Are you still mixing in the box on a S6?
Are you mixing mostly on the control surface vs. the PT Edit and Mix window? All the keystrokes and commands can be accessed and changed on either.
It's the first surface I've used that is faster for most things than using to the PT GUI.
But I haven't mixed on an Icon enough to give a fair comparison. But with the Artist series, Control 24, etc., I usually went to the mouse most of the time because paging through knob functions on a surface is too slow. I don't have that problem with my S6. Make sure you are running v2.1 on the S6 you are working on. They added a lot more functions to the soft keys in the factory app set. To answer your other question, my two favorite features: 1. expand button on the process module to spill a function on the entire knob section. 2. nested VCAs for navigating a session. I hardly use VCA's for volume automation, but on the S6 I use them to organize and spill my track categories (i.e. FX -> BGs -> Crix).
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
Almost completely on the surface. One might need time to really be comfortable to use the surface only for most part, but it's fast and more intuitive to mix this way imho.
my blog:Tamas Dragon |
I mix into a Burl B32 summing mixer. It by itself makes a very subtle difference (smooths the top end in the 3-8k range), but I turn on the BX5 transformers, then run that into an API 5500 into an API 2500. With the transformers and opamps it very much takes on a console feel/sound to me.
There's a very small number of operations I cannot execute from the S6 surface - the most painful being the inability to create sends and inserts on the fly. On Icon D-Control it was a two-click operation.
Otherwise, the waveform display is brilliant and the level (or any other parameter) overlay is fantastic. I also use the Master Module touchscreen for panning, much better than Icon's joysticks or pan touch screen. That being said, I do not look at the Pro Tools edit or mix screen, as most of the visual information I need during the mix is available on S6 screens. |
The M40 master module can have the screens, so you can edit waveforms, view automation data, etc. That further pulls you away from the computer screen. The M10 master module doesn't allow for the screens, so you still might find yourself looking at the Pro Tools GUI to look at things. That said, you really don't touch the mouse much to mix, even without the screens.
Mixing Midi VS Mixing Audio (sound quality) | DBK | Getting Started | 2 | 12-10-2014 12:04 PM |
rendering Elastic audio stil slow | Zownd | Pro Tools 9 | 7 | 11-18-2010 01:03 PM |
Mixing for DVD compared to mixing for Broadcast | Taddy | Post - Surround - Video | 8 | 09-05-2006 12:02 AM |
Steps in pre-mixing and mixing: How do the pros do it? | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-29-2003 08:28 AM |
Is any one stil using this PCI card | Mocha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-04-2002 09:06 AM |
