Old 04-06-2005, 12:28 PM
KingFish KingFish is offline
Default M-Powered PT LLM w/ M-Audio HW ??
What's the situation recording and monitoring live, "THROUGH" Pro-Tools with the M-Audio setup ?
Is it a solution similar to the M-Box, controlled with mix knobs, and by muting the live rec enabled track ? or is there a software controlled LLM circuit built into the HW, similar to the 001 / 002 allowing you to switch the live rec enabled track monitoring, to the LLM circuit, for monitoring through the track ???
Anyone know ?
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 04-06-2005, 01:18 PM
Bazzle Bazzle is offline
Default Re: M-Powered PT LLM w/ M-Audio HW ??
Dave download the demo and try it..I just installed, gave it a listen and then uninstalled..Maybe when I have more patience and time I will reinstall the demo and give it a more thorough investigation.I can forsee the crackers all over this, like stink on a monkey.
Bazzle
Old 04-06-2005, 01:36 PM
I don't have any M-Audio H/W to try it out with, and the LLM situation with the M-Box is a HW feature that doesn't exist.
if the LLM scenario works like an 001 / 002 I'll likely replace all m-boxes from the studio and home with the M-Audio HW equivalent.
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 04-06-2005, 01:59 PM
The 24/96 has a software mixer section with patchbay/router and I expect that is what you would use in place of the Mbox's hardware monitoring.I will check it out again later.
Bazzle
Old 04-07-2005, 03:24 AM
Loudnoize Ent. Loudnoize Ent. is offline
If I'm not mistaken, both the 2496 and the 192 has a monitor mixer, similar to Motu's Cuemix, which simply gives me ZERO-LATENCY... Unlike the bullsh*t we have to deal with the MBox. Please tell me I'm right.
Old 04-07-2005, 10:05 PM
Skyflash Skyflash is offline
I've used it and everyhting runs fine on my Delta 1010lt.
The latency is great...near zero and much better than my M box.
I opened an aux channel assgined an input from my Delta,and plugged
a bass in and there was no noticable latency or Delay what so ever
and that was at 128 buffer.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
PT m-powered doesn't see sp/dif from m-audio 2496 ktommy Pro Tools M-Powered (Mac) 8 11-30-2006 10:38 PM
PT M-Powered with FW400 bus powered audio drive? bruceup Pro Tools M-Powered (Mac) 5 07-06-2006 01:32 PM
Who uses an M-Audio 410 and PT M-Powered? holyspicoli Pro Tools M-Powered (Mac) 4 05-15-2006 09:21 PM
m--audio transit with m-powered clusterer Pro Tools M-Powered (Mac) 4 12-24-2005 11:25 PM
M-Audio Powered and PT FREE GaryMC1 General Discussion 0 04-07-2005 08:46 AM
