Old 12-07-2008, 06:37 AM
dmh dmh is offline
Question PRO-TOOLS DOESN'T START after installation of ADOBE software
I just recently installed new software to my computer: Adobe Master Collection CS4 (photoshop, illustrator, premiere pro, etc.). I also installed a usb pen tablet system, wacom intuos 3. I also updated my computer to Windows XP SP3.
My computer is quad core, 2.8ghz, 3GB RAM. I use a digi002.
After the installation of the new software, pro-tools 7.4 will no longer start. In fact, Ableton LIVE won't start either. Both programs get hung up as they load. I suspect that it is a problem with the audio driver loading for the digi002.
Pro-tools worked just fine before the changes, as did Ableton LIVE. Anyone experience this? Is this a known compatibility issue? How can it be resolved?
Thank you to anyone who might be able to help !
Old 12-07-2008, 07:33 AM
Default Re: PRO-TOOLS DOESN'T START after installation of ADOBE software
Try a system restore(if its enabled) or uninstall Adobe and see what happens.(this is why my PT system does nothing but audio)
Old 12-07-2008, 05:53 PM
dmh dmh is offline
Thanks for the help.
I agree with the idea of using only one computer for audio. There are many professionals, however, that use Adobe software in parallel to Pro-Tools for movie making. I thought that I could do the same.
Anyway, I have tried system restore. Curiously, although the system is successfully restored to a point prior to the Adobe software installation, the problem still persists (the Adobe software, even after the restore, is still installed). I suppose that I would need to remove the software as well (unfortunately, it took hours to load !)
Has anyone successfully used Adobe software CS4 and pro-tools on the same computer?
Dave H
Old 12-07-2008, 07:08 PM
The Weed's Avatar
The Weed The Weed is offline
Time to buy Acronis True Image Home, Ghost or a similar imaging/backup program and use that before installing anything new. You would have been back to a stable-state system in 10 to 20 minutes.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-07-2008, 08:53 PM
Cheers,
A great bit of advice there. I always have a clone of my last working system drive in case an install or upgrade goes sour.
Old 12-07-2008, 09:15 PM
spkguitar's Avatar
Also, that's quite a lot of money to be spending on software that wrecks your system. I would seriously contact Adobe and pitch a fit.
Also,
Could you name one? I'm just curious. Maybe you could contact that individual for some pointers?
Old 12-07-2008, 10:37 PM
Rail Jon Rogut Rail Jon Rogut is offline
Try reinstalling the Digi ASIO driver.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-08-2008, 02:56 AM
dmh dmh is offline
OK. I'll give this a shot.
Do I need to uninstall the current driver first? If yes, how do I do this?
Old 12-08-2008, 09:22 AM
Run the Pro Tools installer.. it'll give you options to install/uninstall.
Rail
Platinum Samples
Are software like pro tools or adobe audition mainly for complex sounds(for film)? skaros23 Pro Tools 10 4 03-18-2013 06:57 AM
Pro Tools 10 Software Installation rodproctor1 Pro Tools 10 2 04-18-2012 09:21 AM
Pro Tools LE Hanging on Start Up with installation of secondary internal HDD plangentmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-10-2010 10:51 AM
Pro tools 8 installation software frozen on start brucewov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-19-2009 02:45 PM
Help with 003 and Adobe software markblasco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-14-2009 10:15 AM
