Old 10-05-2016, 07:56 PM
groovilator groovilator is offline
Default Sudden inability to record
So I sat down to do some punch-ins on an acoustic guitar track that had been recorded direct from a DI. I recorded a few seconds of audio, no problem, then decided I needed a little EQ adjustment but didn't want to mess with the settings on my DI (which runs on phantom power).
I then inserted a small passive mixer into the chain. But when I re-engaged the record button on the track in the session, the level meters on both that track and the master fader spiked even though there was no audio.
When I hit play with the track still in record mode the meter spikes went away and the previously recorded audio played just fine. When I tried recording on the track the meter spikes stayed and my guitar signal wouldn't come through.
I restarted the computer four different times and opened different sessions and the problem persisted. I also went back to the original configuration, sans mixer, with no improvement.
It's baffling to me how one moment everything is working fine and the next moment this problem just springs up and won't go away.
I've run into this problem before and the restart usually fixes it.
Here's what I'm using:
PT 12
MBox 2 interface
Mavericks 10.9.5
Macbook 17 (circa 2009)
8 GB RAM
2.8 GHz Intel Core 2 Duo
Nobody told me there'd be days like these .. .. .. strange days indeed .. .. ..
Old 10-05-2016, 08:49 PM
YYR123's Avatar
YYR123 YYR123 is offline
I bet the Mic input just went out...
1st time Di out is line level.
2nd time mixer out is line level also but if it clipped the input I wonder if the gain was too high on the mic pre and the output was too high on the mixer and it overloaded the mbox pre.
Test it with the DI on the other mic pre........what happens.
You can also run the DI into the back inputs 3 and/or 4 , b/c those accept line level inputs also
Also it's why they say to start out with the levels very low...
Daniel
Old 10-05-2016, 11:03 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Sudden inability to record
Where in the chain did you insert the mixer - between the DI and MBox? What kind of mixer is it (Manufacturer/Model)? If your DI requires phantom power then the mixer may be preventing it from going through. Also, you could be sending phantom power to the mixer which could potentially damage it.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-06-2016, 10:50 AM
Yes, I put the mixer after the DI in the chain which is how the original live recording was set up. I turned off the MBox's phantom power and turned the mixer's phantom power on to power the DI (which I forgot to mention is an LR Baggs Para Acoustic DI).
The mixer is a small 4 channel Yamaha MG06X.
Old 10-06-2016, 04:36 PM
After a quick test I've determined that I did, indeed, overload the preamp on that channel and now it seems to be no longer useable. Which sucks.
So it looks like I'm on the market for a new interface. And I think I would want to upgrade, if I'm already spending money on this, to something with four inputs.
I wonder if I could get any suggestions for a very simple compatible interface that would allow me to record four tracks at once that doesn't cost too much. Could be third party?
Old 10-06-2016, 05:04 PM
YYR123's Avatar
What is the budget?
What's the interface connection type, required if any?
Daniel
Old 10-07-2016, 12:03 AM
This might be unrealistic for a four input interface but I'd like to keep it under $200.
And the connection on my machine will be limited to USB because I have three of those and only one Firewire (800) connection, which I use for my recording drive.
Old 10-07-2016, 09:22 AM
YYR123's Avatar
Try a used Saffire or Scarlett
Like this
http://www.guitarcenter.com/Used/Foc...C-adType%5EPLA
Daniel
Old 10-08-2016, 11:04 PM
Perfect! I'm gonna get one! Thank you!
I can't record all of a sudden! please help!! guitchick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-20-2012 07:43 AM
Hyelp! Strange Inability to record neomodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-28-2005 06:46 PM
my inability to record jrspoon Storage Subsystems 0 10-13-2004 05:11 PM
Can't Record MIDI all of a sudden???? joe h. MIDI 0 05-04-2004 07:19 AM
All the sudden, I can't record, what the hell? mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-28-2001 12:20 AM
