Old 04-20-2018, 12:31 PM
mikedarolfi mikedarolfi is offline
Default CPU Spikes SOLUTION for Protools 12.6 (may work on other version too)
I think I found a solution for the cpu spikes in protools for windows 10.
No sure how to do these steps in other version of windows or mac (or if its the same) but if you can figure out how to get to the same window then try it and let me know if it works.
(while protools is running with a session open) If you open task manager, click more details on the bottom, then go to the details tab on the top (between users and services), find protools and right click on it, click on "set affinity", turn off core 0 or 1 (I believe that any of the cores being turned off may work, but I only turn off core 0 out of 12 on my cpu).
you should see the 100% spike go down to what your actually cpu usage is at (which can be viewed on the task manager on the tab "processes"
If I didn't work, make sure you disable any heavy plugins like AAD or ozone stuff, etc... by pressing the ctrl and windows key together and click on the plugin. bypassing the plugin (when it turns blue) does not turn it off. it must turn dark grey.
The only problem with this solution is that it has to be applied every new session you open, or every time you open protools which is a pain.
Let me know if this worked or did not work for you.
Also, if you know a way to make it so you don't have to apply this solution every time you open a new session then I would love to hear it.
If you are a computer wiz and could let me know why that is happening then I would greatly appreciate that too!
Old 04-20-2018, 06:32 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: CPU Spikes SOLUTION for Protools 12.6 (may work on other version too)
Long Thread about this already.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-22-2018, 12:10 PM
Ya ive seen all of them. wasnt aware of anyone posting this solution so i thought i might as well instead of replying to every thread. I havent seen anyone with this solution but if there is a thread with it, sorry for making another one.
ProTools CPU spikes after CPU fan failure amishsixstringer Windows 24 03-05-2018 10:02 AM
CPU Spikes, 12.5, and processor affinity... Work-Around? 59.9hz Pro Tools 12 12 07-22-2016 10:42 AM
Protools 10 using .aax version of NI plugins, won't work. How do I switch it back? Kieran-Joseph Pro Tools 10 3 04-24-2015 04:43 AM
Protools 8 cpu error and spikes fix! broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-13-2010 04:58 AM
Will files on CD-R version 4.3.1 work w/version 5.0 LE or TDM? coaster General Discussion 2 04-05-2000 12:58 AM
