Did I buy the wrong version?
I bought Pro Tools M-Powered. All I really need is the multitrack editing features - I don't need to be able to attach hardware.
I installed OK but when it starts, it's asking about the hardware. Is it possible to bypass that somehow and go straight to the multitrack editing? Or should I have bought just the Pro Tools LE? And if that's the case, is there a simple way to exchange it? The store that I bought it at (Best Buy) doesn't have LE - just M-Powered. Thanks for the advice! |
Re: Did I buy the wrong version?
M-Powered and LE both require hardware to run.
For M-Powered, you would need a supported M-Audio interface. If you don;t need to record, you might go with an Mbox 2 Micro which includes Pro Tools LE software. |
So I guess my question is, I want to use Pro Tools like Adobe Audition on the PC-side. I have music and voice tracks and other elements I want to process and mix. Can I bypass the question about hardware and just use it as a multitrack mixer? And if so, how?
No
Since you already have Pro Tools M-Powered, you could get the M-Audio Transit:
http://www.m-audio.com/products/en_us/Transit.html or the M-Audio JamLab: http://www.m-audio.com/products/en_us/JamLab.html Those would be the smallest M-Powered compatible devices, both under $100 list price. A little larger, and not much more expensive would be the Fast Track USB: http://www.m-audio.com/products/en_us/FastTrackUSB.html
Administrator Avid Pro Audio Community |
Digidesign, that's very helpful. You anticipated my next question and answered it before I could ask.
Is it safe to assume: I could connect the M-Audio Transit to copy audio off some of these minidiscs I have lying around, and as long as I had it connected I could drop in the other stuff I want to mix? I appreciate the help! |
Just so you know, NO PT software will run without hardware. It's a hustle. I understand that you only want to edit, but the hardware is just another way to make money. I recommend buying an mbox (you can find them used) just to give yourself some recording capability. The Transit is the cheapest option, but it has a little 1/8 plug and reduced sound quality. If you know you'll NEVER want to record analogue into PT, then go with the Transit.
best
last: PT11.3.1 |
Wrong PT Upgrade version?? | 6figgas | macOS | 2 | 12-30-2012 04:28 PM |
Smack LE V8 showing wrong version ??? | Basevoid | Pro Tools M-Powered (Win) | 1 | 02-23-2010 01:45 AM |
wrong xpand version in PT8 | Greg555 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-02-2009 06:59 AM |
Xpand wrong version in PT8 | Greg555 | Virtual Instruments | 0 | 03-30-2009 08:15 AM |
10.4.6 wrong version -- help! | rbny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-26-2006 09:07 PM |
