VENUE Plug-in problem, jerky
Hello!
i have a Venue profile with version 3.1.1.286. The problem occurs when I use any plug-in, when I operate on the plug-in every 5 seconds the plug-in locks for 2 seconds in which I can not control any parameter, even the meter goes into freeze for 2 seconds, is a cyclic problem. It's just a problem of visualization and operation,the audio signal is fine. I thought it could be caused by the EcX driver for remote control, but I uninstalled it and the problem remains. I run the DigiTest and it's all right. Can you help me? Thank You |
Re: VENUE Plug-in problem, jerky
Just an idea - if there is a certain plugin you see this on, try to disable all the rest of the plugins only and have that one enabled and see, if the sluggishness goes away. If it does, start adding back the plugins in half patches, not all together (remember what ones you enable back) and test each time for the sluggishness to re-appear. This way you can filter out if you have a plugin installed that causes this issue.
Have you tried doing a restore of the console? I would imagine that some plugin install has screwed something up a bit.
Plug-ins on Venue? | nickdesigner | VENUE Live Sound Systems | 19 | 12-16-2015 12:18 PM |
Odd plug-in problem VENUE | mbm1987 | VENUE Live Sound Systems | 3 | 04-02-2013 10:11 AM |
Venue 3 and Plug-In Thumbnail Problem | Kenmillerjr | VENUE Live Sound Systems | 9 | 08-08-2012 03:08 AM |
VENUE stock plug-ins | Jason Stygar | VENUE Live Sound Systems | 5 | 02-17-2011 08:40 AM |
Suggested VENUE plug-ins | mariobenipayo | VENUE Live Sound Systems | 10 | 08-09-2009 08:55 AM |
