Re: "some bus paths were made inactive..."
If you look at your I/O setup, I guarantee you'll see the offending bus/input/output there.
The bug is that if a track has an input or output assigned to a non-existent (inactive) bus/in/out and you then delete the bus and assign the track to "no input/output" and close the session, the track will come back with the inactive assignment when you re-open. You have to assign the offending track to an *existing* input/output, close the session, then re-open the session; then you can assign the track to "no input/output" and delete the inactive buss/in/out and all will be well. It's annoying, but once you figure it out it's an easy enough workaround. Certainly wish Avid would take care of it though. best, rich
I know its a different topic, but the other day was recording a virtual synth in Pro Tools.. Once I had recorded, I went through the steps it takes to record the virtual track into an audio track. And I though - this process could be so much simpler. Do you think Avid would do that? Instead of going through the cumbersome routine of making an audio track/assigining the busses of both tracks etc? |
Always keep a clean copy of your IO settings handy. |
If you click the instrument tracks output, you can choose "New track...". Then PT sets the output to a unused bus, creates a new audio track, and assigns its input to the same bus. |
This started with Pro Tools 9 for me. It happens every time I open a session. Nothing I do in the I/O panel fixes it. I can reset all the I/O and create a new session and when I reopen it I will still get the message. Funny thing is it doesn't seem to affect anything at all.
Thanks Ben!!
Hey Ben, I couldn't make this work.. 1. I recorded on an instrument track. 2. I created a new audio track 3. the audio track i have just created is not showing up as an option from the instrument output. My other tracks are though |
I don't understand.
You want to send audio from a track to another, you set its output to a BUS and the other track's INPUT to that BUS. That was the point of my new-track tip. It's just basic PT routing. I was in the middle of answering the thank-you when you posted again: Glad you liked the tip. Also, you can do this to several tracks at once by selecting them and holding option-shift (mac), and it affects all the selected tracks. F.ex bussing all the drums to an aux. |
I have the same issue. It's part of my startup routine to get rid of that dialog, every time. It strikes me as completely amateurish. Where's the QA?
It's amazing that they haven't put in a fix or workaround for this. At the very least, put in a UI option so that the warning is not displayed. Dean Quote:
Please help! "Some paths were made inactive..." | midnightrambler | Pro Tools TDM Systems (Mac) | 16 | 08-19-2016 12:23 PM |
The input path "S/PDIF L-R" was made inactive because its stem is missing. | ampnerd | macOS | 3 | 02-05-2014 08:58 PM |
Freeze when "Some paths were made inactive..." message appears (10.3.6) | SlicerSounds | Windows | 1 | 07-07-2013 10:20 PM |
PC freezes when "Some paths made inactive....." message appears (10.3.6) | SlicerSounds | Pro Tools 10 | 0 | 07-04-2013 11:11 PM |
PT 7.4.2 upgrade from PT6 "Compressor (3)" made inactive could not be found?!? | ominous1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-18-2008 11:48 AM |
