Old 01-24-2021, 06:39 PM
fsavell fsavell is offline
Default Offline Bounce issues with HDX
Does anyone have problems (freezes, hangs, glitches) when using Offline Bounce with their HDX system?
I have a new 2019 Mac Pro HDX2 system (details in sig below). Pretty sure these issues were happening with my old 2010 Mac Pro too, but I never investigated. This has been going on for some time but I've recently mixed an album on my laptop and transferred to HDX system, which has highlighted these glaring issues.
I find I can offline bounce occasionally without issues but often find that it will freeze on the 0:00 mark of the bounce, or hang after its completed and (when selected) not import the finished bounce. I can usually find the completed bounce in the Bounced Files folder and import (after a Force Quit and restart). Lastly, sometimes the correctly completed bounces have glitching all the way through the file, like a layer of distortion.
All plugins are Native in these sessions, to avoid any DSP>Native conversion, even though that shouldn't be an issue!
The same sessions that have these issue under HDX work absolutely fine on my Macbook Pro (2020.12/OSX10.14.6) running in Native. No Offline Bounce issues whatsoever.
I realize Offline Bounce is probably not used often by HDX users because of hardware use & the need for real-time bouncing, but if you have any experiences with it, please chime in.
Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2
Old 01-24-2021, 08:01 PM
Default Re: Offline Bounce issues with HDX
So if you open these sessions with Built In Output (or similar) as the playback engine. Do they bounce OK then on the same Mac system?
What other troubleshooting have you done? Trash prefs? Check all plugins are up to date? remove all .aaxplugin files and see if it will bounce with just the default plugins?
Old 01-24-2021, 08:52 PM
In the middle of mixing albums and haven't had a chance to deconstruct the system to problem solve. It's not a show-stopper so I'm working around it. Just trying to gauge community experience, not trying to solve this one here. Preferences have been trashed.
Old 01-25-2021, 02:42 AM
LukeHoward LukeHoward is offline
It's been pretty reliable for me, also on a 2019 Mac Pro with HDX.
https://lukehoward.com/
Old 01-25-2021, 08:02 AM
Just trying to gauge community experience, not trying to solve this one here..
For whatever it's worth, totally solid here - no issues - daily use of BTD offline on large high sample rate sessions - actually, don't think I've *ever* had a hang on offline bounce on any of the rigs I work on.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-26-2021, 05:26 PM
Thanks for the feedback folks!
Forrester
Old 02-08-2021, 08:00 PM
blastula blastula is offline
PT (2020.9.1 HDX) usually freezes when I try to bounce offline.
Trashing preferences seems to cure it, for a while.
Offline bounce timing issues with some plugins and parallel processing busses aidyhall Pro Tools 2018 25 03-28-2020 02:10 PM
HDX and ADC issues offline bounce brianjanthony Pro Tools 2018 15 08-05-2018 01:11 PM
Offline bounce to disk issues noiseboyuk Pro Tools 12 9 01-13-2016 05:47 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Offline Bounce Pro Tools 11 delay issues dizzydiscs Pro Tools 11 4 11-09-2013 05:48 AM
