#101
Re: Fast Track Pro out of order after last driver update
Yes, that workaround may work, however you are not using an ASIO driver which would give you low latency recording. You might be able to get better results with also using ASIO4ALL, however, none of that would work as well as a properly functioning driver from Avid.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
#102
Today I have solved the problem: Bought Focusrite Scarlett. Working flawlessly.
Never Avid again. |
#103
SOLUTION !!!!
I have a hope for all of you with this problem. Don't get me wrong, I really bought the Focusrite Scarlett. But the day after I had one more idea and IT WORKED!!! So... using DPC Latency Checker and many hours on Google I found this guy (he really deserves the credit). It was pointed out that new Intel network drivers can interfere with audio drivers. Try this: uninstall the network drivers from your device manager. You can disable the whole interface also, unplug the cable, just completely disable your wired network. Reboot. Uninstall your avid drivers. Reboot. Install the newest drivers from Avid. Reboot. ENJOY! I am testing this, and latency under 1ms, no scratches, no dropouts, winamp works, streaming works, youtube works! I am using the latest drivers. Then you need to install OLDER drives for your network card. Follow the guide in the link, or google older drivers as described. I am using the driver from HP site on my Lenovo and everything works now. Still mad at avid tho, but little less now Hope it helps! |
#104
WOW!! Thanks for this, and as it happens im using a Lenovo x220. I really should have searched on thier site. I'll give it a go later on when I buy a msata SSD for it and do the OS reinstall
#105
I'm still pissed at them, they should have found this out and put it in their support long ago. That, and also that they dont give a rats arse about you unless you spend thousands with them
#106
@ Ard: I have forwarded your post on to Avid for them to look into.
Thanks for posting your workaround!!! Joel
#107
Hi JoelG,
I've the same problem reported by others with my Fast Track Pro interface. After install the drivers 6.1.10 and inadvertently also the firmware 1.0.2 a lot of noises, clicks, pops and interruptions are noticeable. Outputs 3 and 4 become dumb, silent. I've unninstalled the driver and installed old 6.0.7, folowed the guide to windows optimization, but the problems persists. Also tested on Mac OS X, and the same happens. The new firmware seems to be the cause of problem. Any solution ? There is a new firmware on the way ? How to repair my device ? PN: AU02-073B0 SN: 200Z073017F30 Computer: Macbook Pro MD101xx/A Core i5 4Gb Memory, 500Gb Last edited by jmmaciel; 04-20-2014 at 06:57 PM. Reason: improve description of problem |
#108
Thank you so much for the hint!
In my case (Asus H87-Pro) I deleted both the drivers for Fast Track Pro and LAN. Then I reinstalled the newest Fast Track Pro driver and an updated version of the LAN driver by Realtek. No problems / dropouts / glitches so far. My device works again now! |
#109
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#110
Hi everybody,
Already done these steps several times, disabled network, deleted network drivers, installed new ones, but nothing brought back the sound of analog outputs 3/4. I still have the same problems these guy: http://forums.m-audio.com/showthread...headphones-out We're still waiting for Avid to release a new Firmware that corrects that problem. Peace! |
win 8 installs own driver for Fast Track Pro | clsbd_lou | General Discussion | 2 | 02-12-2014 06:49 AM |
Driver problems with Fast Track Pro USB | musictomyears | FireWire & USB Audio Interfaces (Mac) | 1 | 10-15-2013 12:16 PM |
Fast Track Ultra 8R Driver | Beto Chaves | macOS | 1 | 10-13-2013 02:53 AM |
Problemo of new Fast Track 6.1.12 driver | tkrojam | FireWire & USB Audio Interfaces (Win) | 2 | 07-20-2013 10:17 PM |
