Sample Rate Mismatch... How to export files as regions after problem.
Okay. I started a session with 44.1 K settings, but I forgot to change my digital mixer board settings to 44.1 K (it was set to 48K). When I "Export Regions as Files" They are pitched low.
I have fixed this problem with music projects before by opening a new session, and importing Session data from the other project making sure I tell it not to "Apply SRC". When I bounce the project, it all turns out correctly. But this solution doesn't work when using "Export Regions as Files." When I look at them in the audio folder, they still show up as 44.1 K even though they are in fact 48K files. So when I tell it to export, it just copies the audio to the destination folder which is a confused audio file that thinks it is 44.1 K. Are there any tricks to getting these files to realize they are 48 K so that I can "Export Regions as Files" and get them sounding right?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Re: Sample Rate Mismatch... How to export files as regions after problem.
If you don't want to go to the effort of doing the whole session, then you'll at least have to do it to the exported files. Create a new session at 48K and import just your exported files without applying SRC. Finally, export again and all will be right.
Thanks Top Jimmy.
I tried that. But I couldn't figure out how to import audio files into the session without Pro Tools applying SRC. It wasn't an option in the import Audio Dialogue. Did you find that somewhere else? I only find that option on import session data. Regardless, I just solved the problem. After I imported the session to the correct 48K sample rate session (without applying SRC). I did a Save Session Copy... and it converted the audio files in the copy to the correct formats. At that point, I could export the regions as files and it worked correctly.
Sample Rate Mismatch! (clock 44.1, PT 48) | RhodesB3 | Pro Tools TDM Systems (Mac) | 22 | 11-24-2015 12:17 PM |
sample rate mismatch problem? | Kevin_28 | Pro Tools 9 | 4 | 12-22-2010 11:18 PM |
Consolidate Regions + Convert Sample Rate + Export | SoundReplay | Pro Tools TDM Systems (Mac) | 5 | 10-13-2010 12:04 PM |
Big Ben / PT sample rate mismatch | zakco | Pro Tools TDM Systems (Mac) | 2 | 10-27-2007 06:36 PM |
Pro Tools LE Sample Rate Mismatch Nag | tcassel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-20-2007 12:51 PM |
