Can you run PT HD on UAD cards
I`m new to Pro Tools and never actually saw a PT HD Running live but from what I saw o the web it`s the top software from Avid. So do you need tu use the AVID hardware to run a HD or HDX
Re: Can you run PT HD on UAD cards
The software side can run on any hardware (even built in Mac audio), but the hardware part requires either an HD Native PCIe card or Thunderbolt Native box, or an HDX DSP card. So you can run PTHD software with an Apollo but it's not like running it with an HDX card that uses its DSP. So, the short answer is no, you cannot run HD on UA "cards". See here for more. http://www.avid.com/pro-tools/compare Hope this helps. |
To me, this is a huge miss for Avid. Everyone I know says UAD have not only the best soundjng, but are the very best at emulating the gear they represent. Considering not very many plugin manufacturing companies embraced Avid’s new architecture, just plain stupid on Avid’s part, IMHO!
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go???? |
Thanks for the quick reply
Have a Great Day |
Nope, if you have a Merging HAPI or Horus, or a Focsurite RED or a DAD AX32 with a MiniDigilink port, then you can run an HD|Native or an HDX card(s) with ProTools HD using 3rd party interfaces, which sound better than the HD I/O range.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
but only 32i/o right?
No. 32 per digilink i/o port but 64 per device (because things like the DADAX32 and Focusrite Red have two primary digilink connectors just like an Avid MADI i/o.) Plus, that's the max per HDX or Native card.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Nope, since you are using a mini digilink port, it's still 64 I/O per board, so 64 I/O on HD|Native, and up to 192 using an HDX 3. http://www.avid.com/licenses/pro-too...ink-io-license
it would be a dream to have UAD with digi link connectors..
It would be a dream to run UAD plugins on a HDX card.
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? | relaxo | Pro Tools 11 | 12 | 05-14-2020 02:05 AM |
Are all pcie cord cards, accel cards? | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 11-20-2011 08:41 AM |
What is the thermal output/heat load of HD core cards and process cards? | yosemitesam | Pro Tools TDM Systems (Mac) | 0 | 10-24-2011 02:39 PM |
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in | phatbeatstudio | Pro Tools TDM Systems (Mac) | 6 | 10-15-2011 11:35 PM |
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! | A Spooner | Tips & Tricks | 6 | 07-08-2009 06:55 PM |
