Old 09-30-2022, 09:58 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Default Melodyne audio not playing when selected
When using Melodyne ARA in 2022.9, Melodyne is not playing the notes when I select them with my cursor. In the plug-in version, Melodyne always plays the notes. To complicate matters, the first session I opened in 22.9 works correctly, new sessions don't. I don't see any differences in the setup. Anyone else?
PT 2022.9, Mac OS 12.5.1, 64G, UA Thunderbolt audio
Old 09-30-2022, 01:58 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: Melodyne audio not playing when selected
I can turn that functionality off and on, it appears, through the GEAR menu at top right of Melodyne tab:
"Monitor when editing blobs"
With that off, I click "notes" and hear no sound.
With that on, I click "notes" and hear the clip audio.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 10-01-2022, 11:00 AM
Thanks for pointing that out, I hadn't seen that before. Unfortunately, mine is turned on and the problem persists. Melodyne support is of NO help.
Old 10-02-2022, 11:54 AM
With ARA being so new with bugs to iron out, I suspect there will be lots of times when using Melodyne as an inserted plugin will still be the best option
Old 10-02-2022, 06:54 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
+1 to that. There are definitely lots of minor glitches. However, I haven't had to resort to the plugin yet, and I've been using ARA extensively since it came out.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 10-04-2022, 03:54 AM
Lots of glitches...
Committing the track is one of them. I need to test this more, but one track commit yesterday resulted in a loss of all Melodyne edits. Ugh. This release really wasn't ready for prime time.
Old 10-04-2022, 04:44 AM
midnightrambler midnightrambler is offline
Originally Posted by PhilSchroeder View Post
Lots of glitches...
Haven't had that, but just had this when I disable-committed the Melodyne. (Top track - pre-commit, bottom track - post-commit). Also post-commit has audible clicks at the edit points that aren't audible in the pre-commit version.
http://duc.avid.com/attachment.php?a...1&d=1664883826
Admittedly I was stretching and pulling stuff all over the place, but even so...
Old 01-02-2023, 03:32 AM
dnote dnote is offline
Same problem for me when working with tracks recorded inside ProTools, no output, neither when clicking the notes nor when playing the track.
A workaround for me that worked is bouncing the track and importing it again and applying Melodyne to it again.
Alternative to Melodyne for Audio to MIDI? Or Which Melodyne version? DBK Getting Started 6 12-15-2014 11:33 AM
The selected ASIO audio device could not be initialized. Please choose another audio sarateofilova Pro Tools 10 1 10-20-2014 08:29 AM
Playing a selected clip also plays the start of the next clip Arthur Sauer macOS 7 11-20-2012 02:03 PM
Popped my Cherry - Melodyne Plugin and 7.4cs9 not playing nice remainanon Pro Tools TDM Systems (Mac) 2 06-21-2009 02:59 PM
Pt in solo mode, playing back other files than selected Brave Noise Pro Tools TDM Systems (Mac) 1 08-05-2001 12:14 AM
