Recording into SSD?
Hi ,
Normally we record 100 tracks at a time into a hard drive, now we have the option to record into a SSD. Performance wise SSD is better, but I heard that SSD only have a limited time of writing/reading, if you reach that time, that Data would be gone/corrupt, so is it really safe to record into SSD instead of hard drive? Thank you
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt |
Re: Recording into SSD?
At least with this MBP of mine it is safe to record to the wicked fast system SSD. Haven't had sessions anywhere else since 2013
It's safe, and fast. That said, just make sure trim is enabled, and over-provisioning is in place. Other than that, be sure to have backups on a spinner, because an SSD that goes south will likely take your data along with it. I only use the SSD to work on current sessions, and archive everything onto spinners. Unlike spinners, an SSD on its way out will probably not give you any warning signs. Happy SSD recording!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
With disk caching, I'm not sure it makes much difference other than understanding the limitations posted above.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Recording into SSD?
Good SSDs are likely overall more reliable than the HDDs you have been recording to. NAND cell wear is just not an issue, it's all hidden from you by the controller. And if the drives are portable or in desktop enclosures that get moved around occasionally then SSD is likely much more reliable than HDD. But all this device reliability is really about convenience. Your recordings are not reliably saved until they are on multiple different media in multiple different locations. The thing that (today's consumer/prosumer) SSDs are not great at is long term archival storage. High quality HDD are great for that (and so is HDD in the cloud/online, and optical disc and digital tape (like LTO storage for large facilities) still have places in this puzzle). It is not safe to just say "SSD", there are different SSD NAND storage devices that span orders of magnitude in performance and expected life. You should be describing your computer and needs and asking what SSD to purchase. The blazing fast speed of modern PCIe based SSD like in the MacBook Pro mentioned above mean you can typically mix samples and audio sessions on the SSD boot drive. Even with disk cache disabled, with disk cache enabled you still benefit with faster startup times and can still get overall more reliable operation (fewer hitting disk IO problems). If you have the option look at these PCIe (and ideally NVMe) SSD drives. Sent from my iPhone using Tapatalk |
Yep. But as always, nothing is backed up until it's backed up twice...
If it doesn't exist in 3 places, its not backed up
Now we have said that more than three times it must be true
cool
Exactly! Sent from my iPhone using Tapatalk
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Recording Guitar | Frustrated (no audio on track after recording) | Aftershock64 | Pro Tools | Intro Discussion | 6 | 08-04-2016 10:03 AM |
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
Recording Latency, (Have to shift regions after recording) | brucefielder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-05-2011 04:21 PM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 6 | 04-16-2003 12:32 AM |
