Old 01-23-2017, 02:07 PM
NoamL NoamL is offline
Default How do I convert multi-mono files to interleaved while preserving edits?
'pologies if this is a beginner question
I have a music editing session in Logic X (lots of wavs spotted to specific timestamps, cropped, crossfaded etc).
I need to bring it into PT12 so I exported it as an AAF.
Unfortunately the AAF stores all the files as split, mono .L and .R files. So, when I open the AAF inside PT, it gives me a bunch of mono tracks. I created new stereo tracks and dragged each pair of mono clips onto these new tracks. That fixes things visually and makes it easier to see all the edits.
But the clip list and audio folder are still full of these split files. It's annoying because there are hundreds of WAVs in the session.
If I could, I would just consolidate or bounce all the stereo tracks, but this isn't an available solution because the edits I'm making have to be approved.
What I'm looking for is a way to replace all the .L/.R files in the session with true stereo interleaved files while maintaining the placement, edits and crossfades of all clips in the session. Is that possible?
Thanks in advance.
Old 01-23-2017, 02:16 PM
PMF Media PMF Media is offline
Default Re: How do I convert multi-mono files to interleaved while preserving edits?
"Shift+Option+3" will consolidate the file/s, that is to say, it will create a new file/s that includes any edits and fade positions.
As for transferring audio between Logic and PT, I've found the surest way is to zero all faders in Logic and then "export all audio files as seperate tracks" (not sure of the exact wording, but you'll find it under the File menu in Logic) and this will spit out all of your Audio and VI's as seperate audio files with the same start and end time, these can then be easily imported into PT for mixing - at least that's what I do.
Old 01-23-2017, 02:21 PM
"What I'm looking for is a way to replace all the .L/.R files in the session with true stereo interleaved files while maintaining the placement, edits and crossfades of all clips in the session. Is that possible?"
Hmmm... not as far as I know, other than the steps you have already taken. Probably best to finish the arrangement in Logic and just mix in PT, but it really depends on your work flow.
Old 01-23-2017, 02:22 PM
Yes, the problem is: I can't consolidate the edits. All of my edits have to be approved by the person to whom I'm handing off the session. So all the edit points and crossfades still have to be tweakable, all the referenced audio files still have to be complete even if only a small part is clipped in the session, etc.
Old 01-23-2017, 03:05 PM
priorytools priorytools is offline
Try making a new session. In the new session window select interleaved. Then import session data for any content you need from your previous pt session.
Now bring in your aaf. Your interleaved stereo files from logic will now be interleaved in pt.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-24-2017, 06:41 AM
Hi all,
I've narrowed the problem down a bit, when I export my Logic edit session to AAF it turns everything into dual mono. The files are already disinterleaved before hitting ProTools. So - setting up PT with "Interleaved" and "Convert files to session format" doesn't help.
Old 01-24-2017, 08:52 AM
OMF / AAF from Logic will not support stereo interleaved. I think you're gonna have to live with it.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-24-2017, 10:32 AM
c-tone c-tone is offline
You could duplicate the playlists for all tracks you need to do this with, and then consolidate the files only on the duplicated playlists, then export as interleaved. That way you will still have the unconsolidated tracks available.
Another option, you could just save the session as is (unconsolidated) then consolidate the files and export the interleaved audio, then just go back to the unconsolidated session.
www.clifnorrell.com
Writing Multi-channel Interleaved files EvilRob Pro Tools 10 4 12-30-2014 11:12 PM
batch src and convert LR mono files to interleaved klaukholm Post - Surround - Video 3 06-25-2012 01:16 PM
Stereo Interleaved vs Multi Mono studiojimi Pro Tools TDM Systems (Mac) 17 12-08-2009 11:20 PM
when do I bounce multi mono versus interleaved???? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-08-2007 12:55 PM
Convert L+R files to stereo interleaved.... how? timmygrimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-21-2004 08:32 AM
