Old 06-15-2016, 07:25 AM
NEOpera NEOpera is offline
Default Unable to interact with menus within the Xpand2! interface
The above image shows an example of the type of drop down menu I can't interact with. While I'm able to chose preset patches and adjust dials, any menu that comes up with a white background as above (FX, modulation type, arpeggio direction, etc.) are unusable. Attempts to click dismiss the menu, and the scroll wheel and directional keys have no effect.
The Avid Application Manager claims it is up to date, as is my Pro-Tools install.
Is there a reason for this (e.g. a pay wall), or is my install borked?
System specs:
Windows 10 (I know, not supported, but it hasn't given me any problems with menus ever)
i7 4770k
16 gig ram
Focusrite Scarlet 2i2
(not sure what else would be useful to know)
Old 06-15-2016, 07:47 AM
DonaldM's Avatar
DonaldM DonaldM is online now
Default Re: Unable to interact with menus within the Xpand2! interface
Sometimes a simple reboot of the entire system can fix these little glitches. If not, then try re-installing it. Its possible one of the operational files got corrupted somehow.
Beyond that, I wouldn't what to suggest.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 06-16-2016, 12:47 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I get this also. Usually helps closing Xpand (removing it from the track) and inserting it again.
Old 07-02-2016, 11:14 AM
Kobi Kobi is offline
I have this problem too, can't change the arp rate on one instance but can on another.
1) reinserting Xpand doesn't work
2) creating a new track doesn't work.
Old 07-27-2016, 11:51 PM
unkJE unkJE is offline
Originally Posted by NEOpera View Post
The above image shows an example of the type of drop down menu I can't interact with. While I'm able to chose preset patches and adjust dials, any menu that comes up with a white background as above (FX, modulation type, arpeggio direction, etc.) are unusable. Attempts to click dismiss the menu, and the scroll wheel and directional keys have no effect....
This problem keeps appearing.
Here's the Windows fix - please see Posts #2, #3 and #4:
http://duc.avid.com/showthread.php?t=382775
Pro Tools 2020.3 and 12.5.1 HD - Studio One 4 Pro - Win10 64 Pro – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 04-03-2018, 06:49 PM
bobdamit's Avatar
bobdamit bobdamit is offline
Same issue here. Only the patch menus work. Everything else is dead. My installation is up to date. Xpand! folder is under ...Documents.. as the post above suggests.
Rock Science Audio, Newport
"These bits go to Two"
Old 04-04-2018, 06:12 AM
DonaldM's Avatar
This issue keeps cropping up and it has been reported to AIR...more than once. Try uninstalling and reinstalling your instance of Xpand!. There doesn't seem to be any logic as to the cause that is readily apparent.
Pro Tools 2019.10
Old 04-05-2018, 06:09 AM
bobdamit's Avatar
Yep, full uninstall/re-install did it - Let's hope it keeps working
Thanks Donald
Unable to locate interface? subhumanrecords macOS 3 11-23-2013 07:54 AM
Unable to find audio interface Jala Pro Tools TDM Systems (Mac) 8 07-28-2008 09:36 PM
unable to interface Control 24 and PT gomedoc Pro Tools TDM Systems (Mac) 7 06-09-2008 01:29 PM
how do YOU phisically interact with your PTLE setup? saggsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-18-2002 08:07 AM
Unable to change Interface Options djdiggity Digidesign Hardware & Software 2 12-05-2000 06:21 PM
