  #61
Old 02-18-2016, 08:21 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Originally Posted by zoff View Post
You can do something like this to detect which displays you are using.
Code:
tell application "System Events"
	set the_displays to display name of every desktop
	if "LG43Um95P" is in the_displays then
		my home_script()
	else
		if "Dell 19" is in the_displays then
			my work_script()
		end if
	end if
end tell
on home_script()
	--your home script here
end home_script
on work_script()
	--your work script here
end work_script
THANK YOU, never thought of that. another great tip. Need to explore that too.
one thing I'm noticing with my script, it have some temperamental behaviour, it works and do what I want 10 times, in the same test session, then from some reason it stop doing one or two things.. I do reboot, do it again and it work fine for some time. weird.
Code:
update
Worked like a charm, I just need to check the exact name that the set command result gave and voilá :)
It's sad that the "bug" of 6 seconds
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
  #62
Old 02-18-2016, 06:26 PM
Oliver and Zoff THANK YOU
Here it is what I've done
Click here to see the video
Tomorrow need to add this to a 19" resolution
Thank you once again
Marco Bernardo
  #63
Old 02-19-2016, 01:25 AM
Oliver M Oliver M is online now
Marco,
the video won’t show, its private.
Anyway, when using the method I described above and executing the click by position, you do not need coordinates, nor do you need handlers for different display sizes.
Attached is an example script, it opens the Playlist Selector of Track 1.
For some reason the board didn't allow me to post the code, weird.
  #64
Old 02-19-2016, 01:43 AM
Originally Posted by Oliver M View Post
Marco,
Ive edit the link of the video it should work now.
I didn't have time to test that option but I will do it today :) for sure, your way seems more bullet proof .
Thank you so much Oliver
Marco Bernardo
  #65
Old 02-19-2016, 02:19 PM
clusterer clusterer is offline
Hey Oliver! Thanks for giving us ur app..
I've 1 question.. Maybe it's already possible but would u say it could be possible to paste Plug in settings from AAX plugs to their corresponding Audiosuite plugs; just with using short cuts?? Thanks for info in advance!!
All the best!
G.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
  #66
Old 02-20-2016, 09:57 AM
All the best!
G.
Probably as almost everything the user does manually can be achieved with AppleScript, its just a matter of complexity but I wonder why you want to do this. Saving the settings in the Librarian menu as a preset and loading it in the corresponding AS PI would be easier, no?
  #67
Old 02-20-2016, 08:42 PM
Hi Oliver,
Done, ok ok ok almost done!!
Definitely this
Code:
set {xPosition, yPosition} to position
set {xSize, ySize} to size
is AWESOME, I've just spend two days mangling how to do it and it's working.
There's only two small things that I've managed to get it done but I know is not "bulletproof".
THANK YOU!!!!!!
ps: now I'm cleaning code, to much tell and end tells that can be avoided
Marco Bernardo
  #68
Old 02-25-2016, 01:17 PM
Thnx for response.. I'd need "copy plugin settings from aax plugs and paste them to audiosuite plugs - ideally with one shortcut - because it would be a huge time saver when phase aligning different clips from different mic positions...
Thnx again!
  #69
Old 02-25-2016, 05:49 PM
Originally Posted by Marco Bernardo;2337107
[URL="https://youtu.be/hmHW_WCjrfI"
Click here to see the video[/URL]
Looks great, glad I could be of help!
  #70
Old 02-25-2016, 05:56 PM
Now I'm trying to do a loop with a choose list (infinite until I enter cancel)
I already did this
set SelectedItem to {"1", "2", "3"}
repeat with i in SelectedItem
if SelectedItem is false then error number -128
set selectedIssue to {choose from list SelectedItem OK button name {"Continue"} cancel button name {"Cancel"}}
if item 1 of selectedIssue is {"1"} then
display dialog " YEAH I'm one"
else if item 1 of selectedIssue is {"2"} then
display dialog " YEAH I'm two"
else if item 1 of selectedIssue is {"3"} then
display dialog " YEAH I'm three"
end if
end repeat
It will loop but only the number of the "set" I've chosen in this case {"1", "2", "3"} 3 times.
even for cancel I need to cancel it 3 times ehehe
Marco Bernardo
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
