Old 03-04-2011, 08:13 PM
jrmintz jrmintz is offline
Default Changing note values while changing meter - I'm stumped
I received a midi file in 4/4 with eighth notes quantized as triplets. I want to change it to 12/8 with the eighth notes quantized as eighth notes. I want the quarter note click in the old meter to equal the dotted quarter click in the new meter - the tempo should remain the same. I'm totally stumped. No matter what I do the absolute note values remain the same - the eighth notes are quantized as eighth-note triplets in the new meter. I can't make them conform to 12/8. Can anyone help?
Thanks!
Old 03-05-2011, 03:57 AM
suicune suicune is offline
Default Re: Changing note values while changing meter - I'm stumped
You need to set your tracks to sample ref before you do this. Tick ref always refers to tempos in 1/4 notes, so when you try change it to dotted quarter tempo it's changing the note lengths. I know it's a bit stupid musically speaking but it's just one of those quirks. Try this:
1. Set all your tracks to sample ref
2. Set your meter to 12/8 with click to dotted 1/4s
3. Set your master tempo to dotted 1/4 resolution
4. Change your MIDI tracks back to tick ref
Now they should be on the 1/8s as expected.
To be honest I've largely given up using dotted 1/4 click resolution in triple time for this reason, I just change the meter, leave the master tempo in 1/4s (multiply by 2/3s if you need to work it out - 120bpm dotted = 80bpm 1/4s) and program clicks manually with MIDI loops. Melodyne and some other 3rd party apps won't work well with dotted clicks either.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 03-05-2011, 08:54 PM
Thank you very much, suicune. I stumbled into that solution very late last night - exactly as you describe. This was a midi file that was sent to me by my kid. She needed to transfer it to Sibelius for score and parts printing, but she started sequencing in 4/4. The great lesson is to start in 12/8 if you want to wind up 12/8.
Thanks again,
Seth
Old 10-30-2011, 02:29 AM
sssonic sssonic is offline
suicune, I'm trying to do the opposite procedure and haven't been able to make it work. I want to go from 12/16 to 4/4 using triplets. I followed your instructions setting the click to 1/4 instead of dotted 1/4. The Score Editor still shows me straight 1/16ths where I want 1/8 triplets. Any advice?
Thanks.
Old 10-30-2011, 03:55 AM
Well, I found another way to accomplish this. I used the Time Compression/Expansion tool (TCE) to stretch everything by a factor of 1.333 and then changed the meter. (No need to change to sample based time.)
S5-MC changing meter refs from -20 to -18 Steven1145 System 5 2 10-05-2010 01:05 AM
values changing on L3 bbob Pro Tools TDM Systems (Mac) 10 06-02-2007 07:35 PM
Hear Note While Changing Velocity relaxo MIDI 5 11-16-2005 10:27 AM
Changing Meter digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-27-2005 08:48 PM
Changing Grid Note value on 15" Monitor... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-21-2001 12:32 AM
