Old 10-12-2020, 10:19 AM
ReynaldoPena ReynaldoPena is offline
Default Use Garage Band Library on Pro Tools
Hello everyone,
Hope you guys have all been practicing some social distancing or what have you. I want to use the library I saved/favorited using Garage Band, on Pro Tools. Is this possible? Thanks and any help would be greatly appreciated.
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 10-12-2020, 12:34 PM
Default Re: Use Garage Band Library on Pro Tools
It's not clear how you expect this to work. What do you mean by library? You could be referring to audio sample loops, virtual instruments?, or more that are parts of Garageband libraries.
But assuming the simple case of Loops, they are stored in .caf (Core Audio) format and you could use a third party tool to convert them to a format playable in Pro Tools. Some loops are just audio, some MIDI and audio, not sure MIDI only exists. Do you want the raw MIDI or audio? You might be better off if there is a loop/audio sample you like and exporting that song to disk. But even then, once you have an extracted sample it's not going to work the same as Apple Loops, whether audio or MIDI.
And it might or might not be legally OK to repackage Garageband libraries for use in other DAWs, you sure can't redistribute them as is, but the case of own-use is unclear, may run afoul of other clauses in the EULA if you reverse/engineer repackage things. Maybe safest legally to create what you like in Garageband then save song to disk and important that into Pro Tools.
Or find what you are after in the Pro Tools ecosystem? Or just stay working in Garageband or Logic Pro for all or more of the workflow, especially for compositional stuff.
Old 10-13-2020, 09:03 PM
massivekerry's Avatar
massivekerry massivekerry is offline
You might be able to use Mainstage as a host for your instruments, but I haven’t tried it personally.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 10-14-2020, 01:48 PM
DetroitT's Avatar
DetroitT DetroitT is offline
I use MainStage via IAC bus (core midi) and record the audio analog via another interface (motu 896) into Avid Omni.
$35 for all the Logic Pro VI’s
Footnote
Mainstage /motu is my bootup Piano
Pro Tools and Garage Band tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2011 08:30 AM
Pro Tools and Garage Band caine27 General Discussion 1 10-10-2011 05:09 PM
Garage Band with Pro Tools LE 7? sjmagri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2006 11:55 PM
Using Garage Band samples possible with Pro Tools? ragbor Pro Tools TDM Systems (Mac) 0 06-24-2004 12:49 PM
Using Garage Band with Pro Tools? ragbor MIDI 0 06-24-2004 12:47 PM
