Old 03-29-2008, 02:50 PM
Grainbelters Grainbelters is offline
Default Set up seperate songs from string of songs in one recording
I am a new comer to Pro tools so please be patient with my questions.
We recorded about 11 live songs with 13 tracks into one file. I would like to separate each of these 13 track songs into separate files to work on them. Any easy way to do this? I am new to this so talk slowly!
Grainbelter
Old 03-29-2008, 05:38 PM
Default Re: Set up seperate songs from string of songs in one recor
Cut all the tracks at the same spot to separate regions(you can rename them if you want by double click on each region). Now you have some choices. If you want to totally separate everything, you can export all the regions for any given song to a new folder or even to the desktop. Now create a new session on your audio drive(use the same sample rate and bit depth) and use "import audio to track" and select all the regions that you just exported(select "use current folder"). They should all show up in your new session and if you cut(separated) all at the same spot in the time line, they will all line up with each other. You can also(once you have separated all regions and tracks) do the same(create new session>import audio to track>) and point to the audio files folder of the original session.
Old 03-30-2008, 10:16 PM
3JDamon 3JDamon is offline
Here's what I do:
- Load all the audio into one session called "template"
- Pick a song, time-align and get a general mix set up, save session
- Save a copy of the template session in the name of each song
- Clear away all other audio from each session, preserving time alignment
- Tweak away
It requires stitching the songs back together, but there's usually too much dead air in between anyway.
I was thinking of starting a live recording thread specifically for workflow tweaks like this! I'm curious if anyone mixes in one session without breaking up the audio. This is the other way of doing it, which I'm curious to try:
- load all audio into one session
- set it to record back into the session*
- time-align, get general mix set up
- hit record
- for isolated mix adjustments, hit stop, make adjustment, resume recording from just before the adjustment
- when completed, consolidate mix recordings into continuous file
- load into 2 track editor to edit/master
* set track outputs to aux 31/32, add stereo mix audio track with inputs 31/32 and interface outputs
This has the advantage of being much faster when real-time bouncing, but rather sketchy for me.
uploading songs into Pro Tools from downloaded songs in iTunes? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-17-2009 09:52 PM
Can I ask for songs? Rabidium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-10-2005 06:14 PM
Live Recording... Seperating Songs in PT SergeK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-09-2003 12:30 AM
X-MAS SONGS!!! bi0force1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 67 12-16-2002 10:30 AM
OT Let's have your "Best 12 String Electric" songs! lochgarman1798 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 11-12-2002 09:12 PM
