Split out of (avid)multiband splitter is phasing
I'm using the Multiband splitter to feed an aux track (in my case the low-mid split) and it's phasing with the original signal. Seems like it's not being compensated properly. No plugs on it. Most of the low end disappears when I add that split channel but not perfectly out of phase.
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Split out of (avid)multiband splitter is phasing
http://www.avid.com/plugins/pro-multiband-dynamics
Bottom of the page: Quote:
It says this: You can use Flip band processing mode for results similar to parallel processing without phase issues or having to set up parallel compression routing. What does that mean?
Hi -If I sum all the plug in split AUX outputs and also the main output of the plug in -then invert the phase the on the main post the multi dynamics plug in =sound fully cancel.
This is on a native pro tools system. Cheers Bruno |
Perhaps a simple band pass or HPF & LPF filter could achieve the same thing sans phase issues.
Right- So that's NOT happening on my rig. (HD native)
Is the delay compensation thingo showing green?
Just wondering if its something else in the session that is throwing things off. My test used AUX input track as source what sort of track is your multi dynamics plug in on? |
Yes. I'm attaching a screenshot. (and in case anyone suggests that, even with plus disabled, it still behaves this way.
Take all the splits, break them out each to their own Aux Input, then sum all of them back together while putting plugs on the low mid band that you want. This way they've all gone through the "same routing" |
The channel out?
Avid Pro Multiband Dynamics Question | Cryos | AAX Plug-ins | 2 | 12-30-2015 05:20 PM |
Avid Pro Multiband Dynamics Plug-in - deapth versus ratio | Gm167704 | AAX Plug-ins | 2 | 02-03-2015 01:42 PM |
Avid Pro Multiband Dynamics & Pro Subharmonic | DHL | AAX Plug-ins | 25 | 11-24-2014 07:06 AM |
AVID: Split this forum into Mac & PC soon! | nob turner | Pro Tools 9 | 9 | 11-07-2010 01:01 PM |
D-Control 32 split or no split? | Don Geppert | ICON & C|24 | 8 | 01-30-2007 10:15 AM |
