Old 10-01-2018, 12:47 AM
mihaicoporan mihaicoporan is offline
Default Music cuesheet
Hello there!
I know that there are a couple of threads on generating cuesheets but it seems none answer the initial question so here goes:
I'm editing the music for a couple of TV series and need to generate every month a lot of music cuesheets. Now, the way that do do this is open every project and manually selecting every region (actually a few regions if they are part of the same music cue), double click, copy the name (which sometimes include "-01, -5, -GAIN, -RVB bla,bla suffixes), remember the lenght of selection and paste it in an excel document. And so on for a few hours. Then, return to Excel and manually remove suffixes on every cue.
It's pretty exhausting to do this and i wonder if there is any other way.
I tried cuesheet.pumpaudio.com, save a txt from protools, import in it, but it didn't combined all the regions of one cue into a single one, so i had to manually calculate every cue, then delete de other regions.
I would like to know if it's posible to select a track and press a command and all the regions that are edited (crossfaded or splited) to combine into solid regions retaining the name of the initial region (music cue).
Or, just to manually consolidate 2,3 regions (of the same music cue) and the result doesn't have the name of the track, instead, the name of the first region.
Is it posible?
Thank you!
Mihai.
Old 10-01-2018, 01:34 AM
BScout BScout is offline
Default Re: Music cuesheet
No.
But if you export from Pro Tools the session info (as a CSV) and import into Excel--and know how to use excel--it's not hard to create a text formula to recalculate an output column with that info.
If you aren't that experienced with Excel, find someone local who can help you (it's a comparison array to output the second column and then some trimming of text)
Old 10-01-2018, 02:28 PM
spoons's Avatar
spoons spoons is offline
Try this.
http://petegates.com/pg-pt-session.html
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 04-04-2019, 03:45 AM
Thank you so much!
Pgpt is indeed the best solution.
OMFs from Premiere with MP3 music files have clicks in the music jyellen Post - Surround - Video 4 08-15-2017 08:46 AM
Nifty little Cuesheet app emf1138 Post - Surround - Video 14 03-31-2006 11:53 AM
DAW's and music PMoshay Pro Tools TDM Systems (Mac) 2 01-05-2006 08:11 PM
music packages for music video shoots cwholden Post - Surround - Video 0 03-07-2005 01:37 AM
FILM MUSIC 101: HOW TO SELL YOURSELF IN THE FILM & TV MUSIC MARKETPLACE John Link General Discussion 3 06-04-2002 10:01 AM
