Old 12-19-2014, 02:43 PM
New Hope Media New Hope Media is offline
Default PT 11.3 hangs on Avid Video Engine during launch
I've just installed PT11.3 on my Mac running OSX 10.10 Yosemite.
First let me say I've been running PT11.2.1 on Yosemite without any problems for the last two months.
However after installing PT11.3 when I open an existing ProTools session containg video I get a message that the AVID Video Engine is loading ... well waiting to load... but it times out and all I can do is load the session with the Video Engine OFF and, hence no video.
I'm not running any external video hardware, just displaying my video on the desktop.
I am running an older, non supported AVID 002R but it is working, and has been all along, with PT11.
My System is:
Late 2013 Mac Pro (dusbin)
MAC OSX 10.10
AVID 002R
PT 11.3
10TB LaCie Thunderbolt RAID
Old 12-19-2014, 04:33 PM
DigiTechSupt's Avatar
Question Re: PT11.3 AVID and Video Engine
Is this still occurring after you quit and relaunch PT 11.3?
If so, please delete the PT 11.3 app, then run the installer again.
Please reply with your results.
Thanks,
JC
Avid Audio Tech Support
Support FAQ
Old 12-19-2014, 07:52 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Default Re: PT11.3 AVID and Video Engine
Sorted after reinstall.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 12-23-2014, 04:22 AM
StudioXander StudioXander is offline
I had the same problem. Trashing Pro tools and reinstalling it worked.
Thanks
Old 12-23-2014, 01:13 PM
Exclamation Re: PT11.3 AVID and Video Engine
Thanks for that info. We identified an issue with the installer and are in the process of posting a fixed installer (same components, so no need to download and install again if you have already deleted PT and re-installed).
Regards,
JC
Support FAQ
Old 12-23-2014, 01:55 PM
mano111 mano111 is offline
Had the same problem on a MBP15. Trashing PT and reinstalling solved it.
Thanks
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 12-23-2014, 11:34 PM
Default Re: PT 11.3 hangs on Avid Video Engine during launch
I'm still having issues with video playback like in the earlier versions of PT11. Sometimes I press play and the playback icon just blinks and it doesn't play. Pressing play again a couple of times doesn't work till maybe 5 seconds later and it plays again. Also had a few unrecoverable video errors.
Running with the latest blackmagic desktop video (10.3.2)
Was running PT11.2.1 without any problems.
Old 12-24-2014, 12:24 AM
Think it would be better to open a new thread for this issue as it seems unrelated to original post. Your more likely to get a solution on a new thread.
Old 01-03-2015, 11:36 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
You're not alone, I've identified that Progressive DNxHD and Apple pro Res don't send video from Blackmagic to the TV, only interlaced video (talking about HD).
updated.
The system that have this problems is on Mavericks 10.9.4 and Pro tools HD 11.2.1, I've tried all drivers from Blackmagic since 9.5.3.
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 01-03-2015, 12:37 PM
Meads Meads is offline
Using HD 11.3 on OSX 10.10 and got lots of troubles with ProRes video as well. The whole session becomes completely jerky and sluggish on playback. Everything lags and PT is hardly usable like this. System usage shows less than 10% total.
When I disable the video engine, everything is running fine. Ridiculous.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
HTML code is On
Video Engine Won't Launch in Pro Tools 11 haudio Post - Surround - Video 10 11-23-2014 07:57 AM
Video Engine can't launch soundista Pro Tools 11 1 07-15-2014 04:52 PM
Waiting for the Video Engine to launch nicolasvandooren Post - Surround - Video 8 02-09-2014 02:32 PM
Video Engine Failing to Launch palmer_jankens Pro Tools TDM Systems (Mac) 2 12-01-2008 02:40 PM
