Old 12-03-2019, 07:34 AM
pherzfeld pherzfeld is offline
Default Reset VCA Fader to 0
Is there a way to reset a VCA fader to 0 without changing the assigned tracks? Sometimes I use a VCA as an overall level for all tracks, and sometimes the VCA gets worked down pretty far while the assigned tracks are worked up pretty high.
Old 12-03-2019, 08:47 AM
Default Re: Reset VCA Fader to 0
With no selection in the timeline, right-click the VCA track name to "coalesce vca master automation". VCA master will be cleared to 0 and its associated tracks will remain where they were.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 12-03-2019, 08:50 AM
Hey Rich, thanks for the reply. When you san no selection in the timeline - can you explain a little further? With no audio selected if I choose to coalesce VCA automation all faders just up just as if I had returned the VCA to unity.
Old 12-03-2019, 09:38 AM
Doesn't that work for HD only?
Jack
QAPLA!
Old 12-04-2019, 09:00 AM
Then something else is going on, though I confess I'm not sure what. I take back what I said about timeline selection - shouldn't really matter. Can't think of another reason why this wouldn't work.
To Musicman: Yes, I believe it's Ultimate only; OP didn't specify system details so probably should've qualified that.
Old 12-04-2019, 09:33 AM
There's a super easy way to set the VCA fader to zero: on a Mac option click on the fader in either the mixer screen or if in the edit screen with the fader split out from the track. Same way you reset any other fader to zero. I don't know the key combo in Windows.
Jack
QAPLA!
Old 12-04-2019, 10:55 AM
OP is talking about 'zeroing' the VCA fader while leaving members of the VCA group where they are.
Old 12-04-2019, 11:07 AM
Missed that. How about this one - on the VCA fader deselect the group it's assigned to, make the change, reselect the group?
Jack
QAPLA!
Old 12-04-2019, 11:37 AM
ChuckS ChuckS is offline
This works in the not-ultimate version of PT.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 01-08-2020, 08:04 AM
Not sure what I was doing wrong, but coalesce works just like you guys said. Thanks!
*BUG* Pre-fader sends revert to post-fader upon session restart Nico Breeze Pro Tools 11 7 07-11-2014 10:47 PM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 10:34 AM
Global reset of fader positions Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2006 08:40 AM
