Old 11-04-2010, 01:50 PM
SupreGlu SupreGlu is offline
Default convert session
i have 88.2 k session with 40 .ptf files in the project folder
how can I open 1 of the .ptf (naturally, the fist one of the sequential group) > convert all audio files that .ptf is referencing to 44k (effectively converting the session and the files) > then open all the remaining .ptf files and not have to do a conversion for each .ptf?
similar: if i have a folder of audio files and I know the folder contains every file in a .ptf (but the .ptf belongs to another audio folder / session), how can i get that .ptf to switch to the new folder which I know has the same audio files.
Old 11-04-2010, 02:07 PM
Andre Knecht Andre Knecht is offline
Default Re: convert session
1) Do the conversion for the first session. Save the converted session and all its sub-folders onto a separate drive.
2) Copy all non converted .ptf files onto the destination drive chosen above.
3) Unmount the original source drive.
4) Open the remaining non-converted sessions from the new drive. Perform file-relinking (it should be invoked automatically upon opening each session). Save results.
5) Repeat step 4) for each remaining un-converted session.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 11-04-2010, 02:15 PM
BaileyBass BaileyBass is offline
Create a new session at 44.1.... then import session data from the session you want, selecting everything to import. Make sure you select "copy from source media" although since you are changing sample rates it is automatic. Then you have what you need.
That leaves all your other "stuff" intact.
For the second part of your question, check out the manual.. look up project browser, task window, and Workspace browser. Your question is a little confusing. SB
Old 11-04-2010, 02:19 PM
Hahahahaha.. Andre is right. I realize now that you want to convert 40 sessions. (although it does read rather confusingly) Definitely quicker his way. (even though I probably learned the way I described from him!!) SB
Old 11-04-2010, 03:46 PM
right, that's a big time saver and will help alot.
the second part of the question was more along the lines of...
say I have a session and you have a session = both same audio files folder > you email me a session file of some tweaks you did > ...well, now it seems clear i would just have to drop the .ptf in my session folder then use the pt dialogs to re-link / update locations...
Old 11-04-2010, 06:52 PM
Yes, just make sure that you copy and relink if you want to keep things organized. SB
Help? Can Anyone convert a ptx session to ptf for me?? kebulan Pro Tools 10 2 04-24-2012 04:37 PM
Way to Convert Session Bit/Sample Rate??? From Within Session??? Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2011 09:48 AM
How do I convert a PT session from SD2 to Wav? myfavedave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-08-2008 12:24 PM
Convert Mac session to PC... bigbottombass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-07-2005 04:13 PM
What's the best way to convert a 48k session to 44k ??? dw Tips & Tricks 4 03-13-2000 07:57 PM
