Pro tools stops responding an slow
Pro Tools is slow and stops responding on a blank session
With error Pro Tools can not initialize Saffire Saffire pro Dsp 24 Pro Tools version 11.2 Fresh install of windows 8.1 Only video and audio drivers installed System has 0 hacked software Computer Model : ASUS All Series ASUS MB Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS Z87-K Serial Number : 1308144******** BIOS : AMI (OEM) 1103 01/02/2014 Intel vPro : 9.00.02.1345 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz (4C 3.8GHz, 3.8GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC LGA1150 Chipset Memory Controller : ASUS Core (Haswell) DRAM Controller 100MHz, 16GB DIMM DDR3 1.6GHz 64-bit Memory Module(s) Memory Module : PNY 8GBH2X04E99924-15- 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-27 5-37-12-6) Memory Module : PNY 8GBH2X04E99924-15- 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-27 5-37-12-6) Video System Monitor/Panel : ACI VE248 (1920x1080, 24.0") Monitor/Panel : ACI VE248 (1920x1080, 24.0") Video Adapter : NVIDIA GeForce GTX 460 (7CU 336SP SM5.0 1.45GHz, 384kB L2, 768MB 3.61GHz 192-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 460 (7CU 336SP SM5.0 1.45GHz, 384kB L2, 768MB 3.61GHz 192-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.45GHz, 384kB L2, 768MB 3.61GHz 192-bit) Compute Shader Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.45GHz, 384kB L2, 768MB 3.61GHz 192-bit) CUDA GP Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.45GHz, 384kB L2, 768MB 3.61GHz 192-bit) Storage Devices Seagate ST3750640AS (750.2GB, SATA300, 3.5", 16MB Cache) : 699GB (C:) WDC WD1003FZEX-00MK2A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) Logical Storage Devices System Reserved : 350MB (NTFS) AUDIO (D:) : 932GB (NTFS) @ WDC WD1003FZEX-00MK2A0 (1TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 698GB (NTFS) @ Seagate ST3750640AS (750.2GB, SATA300, 3.5", 16MB Cache) Peripherals LPC Hub Controller 1 : ASUS Lynx Point LPC Controller LPC Legacy Controller 1 : T0 C8-03 Audio Device : MSI GF104 High Definition Audio Controller Audio Codec : nVidia 0012 Audio Codec : nVidia 0012 Audio Codec : nVidia 0012 Serial Port(s) : 1 Disk Controller : ASUS Lynx Point 6-Port SATA AHCI Controller USB Controller 1 : ASUS Lynx Point USB xHCI Host Controller USB Controller 2 : ASUS Lynx Point USB Enhanced Host Controller #2 USB Controller 3 : ASUS Lynx Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter : ASUS USB-AC56 802.11ac Wireless USB Adapter (AES-CCMP, 475Mbps) Operating System Windows System : Microsoft Windows 8.1 Professional 6.03.9600 Platform Compliance : x64 |
Re: Pro tools stops responding an slow
First question is have you disabled the floppy in the Windows device manager and/or BIOS? Yes even if your PC does not have a floppy. This is a Pro Tools 11 bug well discussed on DUC in older threads.
If that is not it, what is the verbatim text of the error message? Thanks for the Sandra report, Socket 1150 motherboards can be problematic for Pro Tools. Besides that nothing else jumps out at me from the Sandra report. Good that you are using a TI Firewire chipset, memory channels match, disks look good, NVIDIA GPU, etc. Make sure the system is fully optimized, power management, USB power management, WiFi, etc. all disabled. Do every last optimization while debugging. Start at the "Help us Help You - READ THIS Before Posting!" link above on ths page. Also trash prefs and database etc. as described here under standard troubleshooting. |
Pro Tools could not initialize the saffire. Please
make sure that the device is configured correctly Is the exact text beyond that it will just stop responding As far as floppy drive I do not see an option inside the device manager I did all the optimizations before I posted |
You disable the floppy controller in BIOS, not device manager. On an ASUS motherboard, hold down "delete" when you boot to get into BIOS.
There isn't any floppy drive setting in this UEFI bios for ASUS Z87-K Where do I go from here? I am completely shut down! |
A few other things I have tried and a few tears
I got the playback counter to finally move in a blank session only. As soon as I add a track of audio, I get the Pro Tools could not initialize Saffire error. I also created a new session and tried to import my song into it and it will not play wit 0 plugins loaded. I was able to edit files and bounce a bass track out of melodyne, with import into session checked, with only 9 tracks of audio in session, I got I have exceeded the maximum number of audio tracks allowed. 1 or more tracks of audio will not play warning. Followed by AEE Error -6009. The system would hang every action I made. I would have to wait sometimes 3minutes before pro tools would respond. On both Mac and PC I have not been able to get a stable pro tools 11 On my Mac it just freezes constantly. So I thought PC would be different but its worse. Just to think of the thousands of dollars I spent getting to this point and have nothing I can use is disheartening to say the least. Do I have to roll back to pro tools 10 and windows 7 to get results? Can anyone else give me any tips on how to get my rig up and running? ~Thank you~ |
You are fine, don't worry about it. Disabling the device or uninstalling the driver in the device manager is just as effective--either way prevents application software thinking there is a floppy dive there to talk to. But the floppy is not your problem here, so lets move on....
Have you tried launching Pro Tools with Run As Admin? Does that help any?
Right Click the PT icon and choose Run As Admin Have you done some/all of the suggested optimizations? http://avid.force.com/pkb/articles/e...dows+8&x=0&y=0
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
player? Did you try all the things in that thread I posted? What system are you getting the 6009 error on? Or both of them. We don't have details of your Mac, so lets just debug on your Windows system. The next things I would do are Double check that your session and all media assets in them are actually on your WDC black audio/session drive (use the project viewer in Pro Tools to conform where the media assets are for that session) and not on the boot/system drive. Where are samples for any VIs installed? (they should be in the boot/system C: drive). What session sample rate are you running at? Do the standard basic troubleshooting steps of trashing prefs and databases, see instructions under the "Help us Help You - READ THIS Before Posting!" link above on this page. Also do this a few times while you try other debugging thigns. What third party plugins have you got installed on the system? Are they up to date/compatible with Pro Tools 11 and your OS versions? Even if they are up to date, always suspect plugins. And they can cause problems even if only loaded, not actually instantiated/used in a session. So remove all third party plugins from the AAX plugin folders, just drag all plugin files to any folder elsewhere and restart Pro Tools and the system default plugins will automatically be put back. Then you can start experimenting by dragging back the third party plugins in batches and seeign when the system has problems. If it does then keep adding or removing plugins until you fild the culprit(s). And if you were instantiating/using some third party plugins in your sessions then suspect those first, but any plugin could be causing this grief. Plugin folder locations: http://avid.force.com/pkb/articles/e...older-location And I don't use Melodyne, but I recall were some known problems with Pro Tools 11 at one time, I hope they were all resolved. And I'll keep saying it, double check all optimizations are made, especially things like power management and USB power management. And the run as admin that brian mentioned.. that will go away if you unisntall and reisntall Pro Tools. and follow the intuitions carefully, that does not mean you are just logged into an account with admin privileges. |
Pro Tools 10 Not Responding - Slow Launch | macdonaldr93 | macOS | 12 | 03-14-2014 04:45 AM |
pro tools slow clicking on buttons or not responding 11.1.2 10.9.1 | Premo | macOS | 2 | 02-17-2014 08:43 PM |
eleven rack stops responding | alexruimy | Eleven Rack | 6 | 06-01-2011 08:25 AM |
Command 8 stops responding (temporarily) | ingriffiths | ProControl, Control|24, Command|8 | 1 | 10-06-2008 12:38 PM |
PT 4 stops responding when recroding | Doppelganger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2004 12:48 AM |
