Recording MIDI from Reason.
Is it possible to program a drum beat in Reason and record the MIDI information into Pro Tools? I'm kind of a beginner - so any help would be greatly appreciated. Thanks!
Re: Recording MIDI from Reason.
you can export midi from reason, then import it into PT, but you can't record it from reason to PT.
i love my apple iPhone! |
No. The rewire protocol does technically allow for this, but not in pro tools.
However, depending how you program the beat in reason, you can export a midi file which you can then import into pro tools.
Cavell Studios |
THANK YOU to all that responded.
Agree. Do the programming in Reason then save the file and import it into PT. If this is the only way you can get your drum sounds that you want.
Or you can progam midi in PT therefore no need to import later on. The end result is the same. I program Reason midi in PT just because it's easier to deal in one program as much as possible. Plus I can see where the midi notes are in relation to the audio in PT, if any.
Digi 002R Factory Bundle P4 2.4 Ghz 1MB Cache 1GB PC3200 Dual-Channel DDR RAM 40GB HDD for OS 250GB HDD for Audio (2) 17" Monitors |
Midi Only Recording in Reason | blueboxed | MIDI | 8 | 09-19-2009 06:51 PM |
Midi Only Recording in Reason | blueboxed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-19-2009 06:18 PM |
Recording Reason MIDI into PT 7.1.1... | rc86mike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-17-2007 10:21 PM |
Recording midi in reason or protools?? | Gaz103 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-15-2006 02:45 PM |
Help recording MIDI on PT with Reason 3.0.5 | desdichadisimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-28-2006 01:44 PM |
