-7100 error along with PT HD 10.3.8
Today I had a series of problems working with a 62 track session. Although using several plug-ins, (TDM comp > eq > eq > de-esser for example) in the past I was able to open much bigger sessions along with HD 8.1.1 cs something. I had repeated -7100 errors, time consuming voices and dsp reallocations . I altered memory/cpu usage, number of processors, etc. I was able to work fine with this setting: 512 samples - 3 processors = CPU 90% - 80 Voices @ 5 DSP Cache size reduced down to only 1GB My main machine is old, a mac pro 2007 with 13GB RAM, but even maintaing the old and reliable OS 10.6.8, seems 10.3.8HD is pretty hungry. What else can be done to avoid this -7100 errors? 66 tracks is not that huge session and I was not even using regular reverbers (Revibe). I changed a few plugins from dsp to native. Is this time for an additional HD accel card?
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
Re: -7100 error along with PT HD 10.3.8
That or an upgrade to HDX. It sounds like you are running into the same type of TDM bugs I ran into with two systems where I work. Avid never fixed the bugs I reported. I don't expect them to fix those bugs at this point. My solution to the problem was to upgrade to HDX.
Wow, so simple solution! Lol
Buggy software released... Spend more money to get rid of it! I imagine if 10.3.10 acts like this too. Anyone?
I just started getting this error on my TDM rig running 10.3.8 (spec in signature).
It came out of the blue and I am now unable to open sessions I mixed in the last couple of days. They were fine when finishing and bouncing mixes but 50% of them now report this error and crash Pro Tools. This is happening out of the blue. Did you ever get to the bottom of your problem?? (I am also suddenly, and for the first time ever, getting bursts of white noise at random intervals which drop Pro Tools out of record).
2x Hackintosh X79 HD7 Accel PCIe, Magma EB7 chassis PT 10.3.10 Mac OS 10.9.5 SSL Delta Link HD 160 I/O COCKOS REAPER (latest) RME MADIFX (192 I/O) ProControl (32 channel) |
For anyone with the same problem:
The error was caused by Sansamp TDM. It disappeared after removing the DPM version of the plug-in and instead using the AAX Native. Eventually I re-installed Sansamp TDM and le Pro Tools re-scanne the installed plug-ins upon launch. The error has not re-appeared since. Please note: Somehow the TDM version of the plug-in must have gotten corrupted. I am not quite sure as I actually put the same copy of the DPM file back into the plug-ins folder after the above procedure.
DAE error -7100 | nathand | Post - Surround - Video | 3 | 04-07-2010 01:08 PM |
Error 7100 and Error 4, tracks have no voices help | WannabeSQ | Pro Tools TDM Systems (Mac) | 1 | 08-10-2006 02:24 AM |
error#4 and error #7100, pro tools crash! | audioluche | Pro Tools TDM Systems (Mac) | 2 | 06-19-2006 06:10 AM |
PT6 error 7100 | AINSLIE | Pro Tools TDM Systems (Mac) | 8 | 03-19-2003 01:27 PM |
error 7100 | mario vejar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-28-2002 08:43 AM |
