Re: Ug, CPU overload on two-track recording a concert
But you should already have gone through all standard troubleshooting/optimization steps, and that includes disabling WiFi and Bluetooth, do every optimization step at once and see if it gets more stable. If you cannot work out how to get a wired keyboard/mouse for a test you have more problems than this..... Screenflow type things make the need to try out careful optimization even more important. |
Why do you suggest this? First time I'm hearing this suggestion! What's the issue?
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Removing Chrome was one of many troubleshooting steps I went through to solve my -6101 errors. There was about a month between recording sessions for that Skype client (worked fine, a month passed, then multiple -6101 errors), so I tried to think of things I'd done during that month. One of those things was downloading Chrome. I have since removed it completely, which is to say I went folder-by-folder through my whole system, library(s), and home folders and got rid of anything Google. I also followed the long list of troubleshooting tips you can find elsewhere on the boards and, as I mentioned, bought Little Snitch to really shut down any non-essential network access while I'm recording. Since then I've had one -6101 error across four sessions, and it was the exact moment I moved my phone (Bluetooth on) from underneath my computer to a spot farther away. So... am I sure it was because of Bluetooth? No. Did I stop using my Magic Mouse? No. Did I turn off the phone's Bluetooth? Yes, and I keep it away from the computer when recording. It took me a solid week to track down the issue, and I still feel a bit on pins and needles when I'm recording that client. But I feel a lot better about it than I did before. |
Sometimes Ilok USB makes conflict with wifi adapters...
Move Ilok USB to another port, or buy a usb2.0 hub.
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. |
This may not help with finding the cause of the error and maybe this is obvious, but for live recording, it is always recommended to record to two separate and independent devices, mostly due to unexplainable and unpredictable glitches such as this.
Stopping recording in between songs can help, but you can also sometimes get the dreaded spinning beachball after hitting stop which can prevent you from getting back into record in time for the next song. Having two recorders can cover that situation too. And yes, check "Ignore CPU errors during record".
www.clifnorrell.com |
I specifically like other software for this task.
I don't like to use PT in the wild (live settings) b/c I don't like to take my Ilok out of its cage. I used Presonus studio one artist, and Presonus capture both flawlessly, both on a studiolive mixer and a Behringer x32. Capture is super simple, artist is cheap, and waves also has a multitrack recorder although I have yet to hear anything about it...good or bad. And best of all, those other programs don't use Ilok....
Boom Recorder ... or 3 Full PT Rigs ... haha
I think the best advice which was already given is NOT to record to the internal drive. Avid states very clearly you should be using an approved external drive or a separate approved drive different than the boot drive
recording concert percussion | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-06-2005 08:59 AM |
Recording Live Concert | Bilnva | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-20-2004 04:22 PM |
Recording Live Concert | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-27-2003 05:03 AM |
Bad Clicking 25 minutes into Concert recording | Cameron_Wiley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-17-2003 07:51 PM |
Recording concert with SMPTE | LiveWire Remote Recorders | Pro Tools TDM Systems (Mac) | 6 | 12-30-2002 07:57 PM |
