re: relinking
Hey guys, can anyone say why pro tools is taking more than an hour and still going as I write this, to relink missing files even though they are all on one drive?
Thank for your time.
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: relinking
For some reason I've never had any luck with this feature either.
In the past I've had to create a new session and import the files back into it. A right PITA. Of course if I'd done a lot of editing I wouldn't bother doing this.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Re: relinking
And here I am after thousand of dollars buying pro tools and thinking I had the best DW, I can't even use it to find a file,that was supposed to be in a session I am trying to reopen, wow.
re: relinking
Yes, if you leave it open to search your whole system, it will take forever if it works at all. If you narrow the search down to where the files are located, it'll happen immediately.
If they don't relink immediately, refine the process by saying to link by name or id only.
Re: relinking
Re: relinking
Post the session and some audio files to Dropbox and I'll see what's going on when I get home tonight.
Re: relinking
If I don't sort this out I will do that, thanks.
Re: relinking
Found the whole file on another disk I had. Thanks for your help
Re: relinking
Glad to hear you got it sorted.
Re: relinking
BUT let's try not to blame the DAW for the operator not making sure the audio files are in the session file folder that corresponds to the session. One thing I would double check is that you have "copy files on import" checked in your preferences. That SHOULD keep this from happening again. The more files that are "somewhere else," the longer it will naturally take to relink all of them.
why do i have to keep relinking | djmichael.london | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-01-2009 05:52 PM |
Relinking | NIckH_UK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-14-2005 09:06 AM |
relinking help | szajac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2005 10:34 AM |
help with relinking | JGuth | Pro Tools TDM Systems (Mac) | 2 | 12-03-2003 03:48 PM |
