Old 04-16-2018, 03:22 AM
Squierfreek Squierfreek is offline
Default Xpand2 is installed but not available? [SOLVED]
Yesterday I opened a project i did not use for long time. While it was loading it said the plugin X!pand 2 is not found in the plugins folder, but the Application Manager says it's installed. I reinstalled Pro Tools already 2 times waht can I do?
Old 04-16-2018, 04:38 AM
ChuckS ChuckS is offline
Default Re: X!pand2 is installed but not available?
What version of PT? I think there was a name change somewhere along the line. It may have been during the transition from 32 to 64 bit? It's now XPand!2 and is a separate installer in your Avid account. Check in your plugin list to see if a different version is already there.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 04-16-2018, 06:04 AM
First, I use 64 bit and the newest version of Pro Tools. The second thing I found out 3 seconds ago is that there's not the old X!Pand2 missing but like you said the new XPand!2. Also I took a look in my XPand!2 plugin folder and found out, thats most of the supfolders are empty. Is that normal? Or is there any possibility to reinstall it? There's no dl link under "my products".
Old 04-16-2018, 09:18 AM
It should be in your account under your annual upgrade and support plan. It's a separate item under Pro Tools Plug-ins.
Old 04-17-2018, 12:39 AM
Can you please give me a more detailed navigation? I do not exactly know what you mean
EDIT : I found out that for some reason i have had the possibility to uninstall more than one XPand setup so i uninstalled all of them and reinstalled Pro Tools. Know it works. Thanks for help
Old 04-17-2018, 01:04 AM
Southsidemusic's Avatar
You will find the installer in your avid account.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Xpand2 not working Mac patches none no sounds SOLVED JCStarbright Virtual Instruments 3 02-26-2018 09:45 AM
[SOLVED] Has anyone successfully installed Waves v9 on 3.1.1? Jeffery Foster VENUE Live Sound Systems 5 06-25-2015 01:53 AM
Xpand2, Vacuum, etc. on 10.3.7 (with 11.0.2 installed) yonkiman Windows 6 12-03-2013 02:30 PM
Rookie Mistake: Installed Xpand1 over Xpand2 LT_CJ Virtual Instruments 3 03-20-2010 04:13 PM
Just installed Trilogy but cant get no sound. (solved) chrisdee Virtual Instruments 32 10-07-2009 07:25 AM
