Old 01-05-2002, 10:45 AM
Target Earth Ent Target Earth Ent is offline
Default CPU and System Levels rise after vocals end...
this happens on 2 different songs. Every time the vocals end for good and the instrumental tracks are just playing....the CPU and System levels rise. Sometimes causing buffet messages. Anyone know anything about this?
Old 01-05-2002, 09:57 PM
Default Re: CPU and System Levels rise after vocals end...
I mean buffer messages [img]images/icons/smile.gif[/img]
Old 01-05-2002, 10:25 PM
Mr_Seven Mr_Seven is offline
This happens to me when using Autotune. I think it has to do with trying to process (tune) an infinity db wave.
Darren Valen
Cyberdream Studios
Old 01-05-2002, 10:38 PM
mattm mattm is offline
it is autotune, assuming you are using it. this problem can be resolved by writing bypass automation to the track. ie. only have autotune active when there is vocal content.
the cpu usage issue will be addressed when antares release version 3 for pc rtas later this year.
~matt
Old 01-05-2002, 10:56 PM
december_sky december_sky is offline
You have a P4 right? that happens a lot on P4s! [img]images/icons/confused.gif[/img]
I have one.
Gabriel.
Old 01-06-2002, 09:49 AM
Gabriel
this happens on all CPU's. the problem actually being in the plug. try what i suggested above.
~matt
Old 01-06-2002, 01:14 PM
I'm not even sure what Auto-tune is. is that a feature within Protools or something extra? If something extra... I'm definatly not using it. It's annoying because even the plug ins are not over using the cpu... it may over use it after the vocals end....before I have enough time to make a decent fade or end the song as I would like.
Old 01-06-2002, 06:08 PM
that's a wierd one. probably speak to digidesign.
Old 01-07-2002, 10:38 AM
DigiTechSupt's Avatar
-What else is in the session after the vocals end (on any track)...are more plug-ins introduced, more automation, higher edit density?...all of these things can effect the CPU performance meter.
-Are you using the generic IDE drivers from the Win98/ME CD-ROM with DMA enabled?
Brent
Avid Audio Tech Support
Support FAQ
Old 01-07-2002, 09:24 PM
which plug-ins are you using on the vocal tracks?
Dramatic pitch rise effect - how to?? phillyt2k Pro Tools 10 9 04-28-2013 11:35 AM
Backing track levels over vocals while tracking? Stixxs General Discussion 5 03-08-2010 06:21 AM
How to Master vocals, levels etc. Before bouncing to Disk? PT-MP Rookie Pro Tools M-Powered (Mac) 20 07-06-2007 04:37 PM
Question w/ recording vocals? signal levels? rpb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-19-2004 04:12 PM
