Old 08-28-2009, 02:25 PM
kirkbross's Avatar
kirkbross kirkbross is offline
Default Quantized MIDI piano part sounds swung?
I have an EastWest QL Pianos MIDI part playing a simple repetitive eighth note part and it's quantized to 8th notes, right on the grid, yet it sounds like it's swinging ever so slightly. Naturally I checked and there is no swing value in place and the velocities of all the notes are the same.
I'm wondering if it could be a "note-specific" latency issue where certain samples are playing a few ms later given the feeling that it's swung? What other parameters should I look at to troubleshoot this?
I'm running PT8cs3 and 10.5.8
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave.
Old 08-28-2009, 11:41 PM
flommer flommer is offline
Default Re: Quantized MIDI piano part sounds swung?
Record the audio output and measure between notes in samples to confirm the swinging..
Do the same phrase but change all notes to the same note, so you would be triggering the same sample (unless the program does that random sample-swapping thing..)
Double check the MIDI event list to make sure the quantize is 100%
How did you quantize? Input, realtime, or applied after the fact?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 09-01-2009, 11:20 AM
kirkbross's Avatar
Step input on grid... I'm going to double check all the variables and also try another piano sample.
Old 09-01-2009, 11:49 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
OK it could just be me, but how can an 8th note sound as though it's swinging?... That'd have to be in ur head almost or something else in the song making it feel as though it's swinging... Just my thought...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-02-2009, 04:17 PM
kirkbross's Avatar
Here's a link to an mp3 of the piano part in question.
http://www.kirkross.com/ftp/piano/
Old 09-02-2009, 04:44 PM
Hagopm Hagopm is offline
sounds swung to me.
Old 09-02-2009, 07:05 PM
sowby sowby is offline
Actually, the opposite of swung. It's early on the 8th notes, but only like every 3 notes or so. Did you check the real-time properties? Make sure the swing is set to 0.
What tempo did you have set for the mp3 you bounced?
www.MyOnlineDrummer.com Custom Drum Tracks
System 1:
PT 10.3.4, 003 Rack, PreSonus DigMax LT
MacPro Quad Xeon 3.0GHz, 16 gigs RAM, Mac OS 10.7.5 Lion
OWC Mercury Extreme SSD system drive
3 TB WD drives, (a ton of) External drives, yada yada My System is cool too, blah blah
Never had an installation problem, incompatibility issue, crash, bug, slowdown, etc.
www.CornerHouseStudio.com
Old 09-03-2009, 05:41 PM
kirkbross's Avatar
FIXED! Unfortunately it's one of those head-scratchers where what I did shouldn't have fixed it.
Here's what I did: I created a click track so I could monitor the piano against it to hear how and where it was off. Presto! Just the act of creating a click track somehow made the MIDI track behave. I also set the metronome value on the transport from quarter note to 8th note and back. I don't know which did the trick but technically, neither should have made any difference. Go figure.
Old 09-03-2009, 06:27 PM
I hate threads that work out like this...
Very unsatisfying resolution....
Except, of course, now it's working for you...
Old 09-03-2009, 08:36 PM
kirkbross's Avatar
Yeah... I agree. All I can think of is that the creation of a click track somehow reset the session's internal clock or something. That makes absolutely no sense, but I have no other explanation.
piano sounds funny when recording with midi scottjoyce MIDI 2 09-13-2010 09:35 AM
Unwanted Quantized Piano Sound beyond MIDI 6 02-27-2009 05:49 PM
GrooveQuantize problem (sounds change after being quantized) TheBaron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-17-2008 11:04 AM
I hear piano sounds in the background of my patch when recording MIDI ra2012 MIDI 8 03-27-2003 11:07 AM
What are you using for Piano Sounds? Jamble Digidesign Hardware & Software 0 04-19-2002 08:27 AM
