Old 02-02-2009, 02:29 AM
lxaudio lxaudio is offline
Default Is it possible to...
... import tracks from some other session BUT only a specific timecode range?
Thanks!
Sérgio
Old 02-02-2009, 02:44 AM
tj_davies tj_davies is offline
Default Re: Is it possible to...
Thanks!
Not that I know of.
If you want to save harddisk space, import the track with "link to media" set.
Once you've imported the track remove the unwanted regions from the track and the bin (Remove don't Delete). Now open the project browser and copy the external files into your audio folder.
Maybe this helps,
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 02-02-2009, 07:36 PM
sowby sowby is offline
You could make region groups in the session you want to import from. Then 'export region groups' in the Regions bin. Then in the session you are importing to, go to File, Import, Region Groups.
www.MyOnlineDrummer.com Custom Drum Tracks
System 1:
PT 10.3.4, 003 Rack, PreSonus DigMax LT
MacPro Quad Xeon 3.0GHz, 16 gigs RAM, Mac OS 10.7.5 Lion
OWC Mercury Extreme SSD system drive
3 TB WD drives, (a ton of) External drives, yada yada My System is cool too, blah blah
Never had an installation problem, incompatibility issue, crash, bug, slowdown, etc.
www.CornerHouseStudio.com
Old 02-06-2009, 01:04 PM
irwinmfletcher irwinmfletcher is offline
Sergio,
Here's the smart ass answer I know you been waiting for.....
Yes there is a way to do this but of have to buy a Fairlight system cuz PT can't.
Sorry I couldn't help myself.
--Fletch
Old 02-06-2009, 01:21 PM
myke2242's Avatar
myke2242 myke2242 is offline
here is what i do. i make a copy of the session which i will be importing from. I then delete everything in the session but what i want to import into the new session. open new session, import to new tracks and drag the regions into place. the i delete tracks.
