Old 09-04-2007, 04:18 PM
Steve MacMillan Steve MacMillan is offline
Default PT 7.3.1cs4 FMP bug
If you have a send that has the FMP (follow main pan) button selected and you remove and replace it with a different send, the FMP button stays highlighted but the new send is not following the main pan. If you toggle the FMP button off and on it works correctly, so I guess it is sort of a graphic issue only.
Power Mac G5 Dual 2.7 GHz, 2.5 GB RAM, OS X 10.4.10
Magma 13 slot 32bit chassis, Atto UL3D SCSI
HD core, 4x Accel, 2x HD Process
1x 192, 1x 888|24, sync i/o
ProTools 7.3.1cs4, Logic 7.2.3
macmandigital.com
Old 09-05-2007, 10:09 AM
DigiTechSupt's Avatar
Default Re: PT 7.3.1cs4 FMP bug
Thanks for the report - we've logged this issue.
Avid Audio Tech Support
Support FAQ
OS X.4.10 & PT LE 7.3.1cs4 Craig Woolard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-10-2007 03:04 PM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 2 07-30-2007 10:13 AM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 0 07-30-2007 12:21 AM
QT7 + PT6.4.1cs4 + OS 10.3.9 = OK? JR Fountain Post - Surround - Video 4 03-09-2006 08:01 PM
PT MIX 6.4.1cs4 who's using? agock Pro Tools TDM Systems (Mac) 10 07-31-2005 05:10 PM
