Old 06-23-2000, 06:12 AM
nickair nickair is offline
Default Recording levels
My name is Nicolas Rochat and I have recently purchased a TLAudio PA2001 mic preamplifier.
I am working with a Digidesign ProTools recording system and I have a Digidesign 888|24 AD/DA audio interface.
The operating level of the 888|24 is +4 dBu, same as the preamp.
I am using the TLAudio preamplifier to record sound with a Røde NT2 microphone, and I set the input button so that the peak LED starts to illuminate.
Then, even if I have the output button of the preamp to full power, the input level I read on my ProTools system is something like 0dBFS -30dB, which is a way not
enough, as I need to have a level as near as 0dBFS as possible.
Do you have any advice to help me reach higher levels when recording on the ProTools?
Thanks for your help.
Nicolas Rochat
Old 06-23-2000, 10:01 AM
Dzerdzinsky Dzerdzinsky is offline
Default Re: Recording levels
When you saythe signal is at -30dBFS, what kind of signal is it? Is it a constant tone or transient material?
If possible, hook you preamp's line out directly into a normal mixer and read the mixer meters. Try to eliminate the mic pre as your problem first, because it is unlikely the 888 is having problems.
Jamie Hardt, MPSE
http://www.soundepartment.com/
Old 06-23-2000, 10:11 AM
The signal is a constant sine that send into the mic preamp and then into the 888. I have switched the 888 into -10dBv and even now, I can hardly reach 0dBFS on the 888. I have quite the same problem if I send a signal directely from the mixing console to the 888.
By the way, if I send a signal through the mic preamp to the mixing console, I read about -7dB. There's really something I don't understand...
Recording Levels in a DAW Kenny Gioia General Discussion 2 08-10-2013 09:40 AM
Best Recording Levels spaceman Tips & Tricks 104 11-26-2011 06:53 PM
Recording Levels ahanslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2010 12:36 AM
Recording levels MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 31 05-31-2004 07:48 PM
recording levels Graeme Oxby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-25-2003 12:06 AM
