Old 02-10-2020, 12:24 PM
Grayel Grayel is offline
Default Monitoring cuts and VST Plugins Issues
Ok guys I am stucked and need help from experienced PT users
I have 2 main issues I need help with
1* I can´t make Addictive Drummer 2 or any other VST plugin to run through PT, already tried a VST to RTAS converter called FXpansion V2.11
It wrapped the VST plugins, resulting in PT shutdown when I try to open any of these wrapped VST through the insert in my PT mix window.
2* I get all my monitoring sounds cutted, any signal coming through PT to my headphones (monitors) E.G. like a single signal generator, I get cutted sounds of that signal, or cutted monitoring from my instrument (Guitar) or from any virtual instrument I try to use from PT.
If any of you can send me some lights to solve these 2 Issues, it will be very appreciated.
Anyway I will keep reading and researching in the internet to try to get a solution.
Very simple set
Computer Model: PC Asus Motherboard Z370P
Audio Interface: Focusrite Scarlet 2i2
SO: Windows 10 pro
ProTools Version: 10HD 10.3.7
Old 02-10-2020, 03:25 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Monitoring cuts and VST Plugins Issues
What may/is probably one issue is W10 and PT10.3.7.
Have a look at the compatibility chart here.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-12-2020, 05:18 AM
Thank you, this gives me a hint.
Very simple set
SO: Windows 10 pro
Low Latency Monitoring Issues jeffn9 Pro Tools 12 3 12-06-2018 01:36 PM
C24 Monitoring Issues Dondusko ICON & C|24 3 05-20-2018 09:50 AM
PT10 - Audio cuts out using most plugins wwboynton Windows 5 12-31-2011 11:35 PM
Monitoring Issues Cobaltsaxman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2007 10:57 AM
PT 6.4 Monitoring, Metering and other issues... Mt.Everest Pro Tools TDM Systems (Mac) 0 06-14-2004 11:46 PM
