One Fader \"Clicks\" until PT Session Opens
I've got a problem with a fader. When I'm not running Pro Tools and all the faders are at unity - say when I'm monitoring from an external source like a CD player - one fader clicks aginst something in the board. The clicks occur about every second like the ticking of a clock. They continue when I open Pro Tools but they go away as soon as I open a session and the fader moves from thre bottom of the board. The clicking also stops as soon as I touch the fader. I've run the tests referenced in the Control 24 Guide including Step Test, Cycle Test, Group Test, Touch Test and Fader Recall and everything checks out thought that particular fader seems slightly jerkier than the others. Does this suggest the fader needs to be replaced? If so, how difficult a job is that? Can it be done without sending the board out of the studio? Any info you guys can give me would be greatly appreciated. Thanks, Marindakim |
Re: One Fader \"Clicks\" until PT Session Opens
bad fader.. I had the same problem. Quick call to digi, they fedexed a new fader which can be easily installed. CTRL 24 never left the studio.
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram 4 internal sata drives (1 terabyte) Magma Pci to PCIe 6 slot chassis PT 8cs3 HD 2 Accel 1 Process Card UAD quad PT 8.0.1 cs 1 OSX 10.5.8 Ctrl 24 |
Thanks Tonicjeff! I'll call Digi Monday morning.
Marindakim : |
Noise when protools opens any session | mgsr70 | macOS | 2 | 12-07-2013 04:46 PM |
Thank you Digi, 8 year old session opens fine! | SlowTools | Pro Tools TDM Systems (Mac) | 2 | 02-27-2009 07:37 AM |
001 session opens for a second, then PT quits | MrShayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-20-2003 04:50 AM |
sometimes session opens from CD-ROM.. | Alécio Costa | Pro Tools TDM Systems (Mac) | 5 | 05-31-2003 10:32 AM |
PT opens, but session doesn't ! | Liquid Jam | Pro Tools TDM Systems (Mac) | 0 | 08-02-2002 10:51 AM |
