Old 06-30-2015, 11:00 AM
Jazzbass56 Jazzbass56 is offline
Default Antelope Orion
Yes Orion tech support sucks big time, that being said the product is incredible I use it every day and it's supper solid, sounds incredible,, it will also work without the Madiface but Madi is the way to go, those who trash the product on this thread, do you own or use the Orion?
Cheers
Intel Intel Core i7-5930K 3.5 GHz Processor
ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram
Thunderbolt EX 2
Windows 10 Pro
2013 MacBook Pro Retina i7 Quad-core, 16gb ram.
Mac OSX 10.11.6
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
Memory 128 GB 1866 MHZ DDR3
Graphics AMD FirePro D700 6144 MB
PT Ultimate 2022.4.0 on Mac
PT Ultimate 2020.12 on Windows
Logic Pro X 10.6
Nuendo 12.0
1_Antelope Audio_Orion Synergy Core Studio
Shatzer Shatzer is offline
Default Re: Antelope Orion
Originally Posted by philip888 View Post
What are your PC specs?
Samsung 850 Pro 256 GB drive (operating system)
WD Caviar Black 500 GB drive x 3 (sample drives and Pro tools)
Radeon HD 5750 1 GB GDDR5 graphics
Sabertooth X58 Motherboard
Intel core i7-930 LGA1336 Socket 2.8 GHz 8 MB Cache
OCZ Technogy ModXstream-Pro 600 Watt power supply
Corsair Vengeance Triple Channel 24 GB (6x4GB) DDR3 1600 MHz
Pro Tools 11.3.1 HD
Windows 7 Home, about to upgrade to 8.1 to access more RAM.
Old 06-30-2015, 05:54 PM
Eric Lambert's Avatar
I don't have an Orion - I have a Satori - but I've had trouble getting tech support, too. At this point I'm entirely unimpressed by the company itself though their products seem to be solid.
Old 07-01-2015, 09:54 AM
philip888's Avatar
philip888 philip888 is offline
Pro Tools 11.3.1 HD
Thanks.
I am going to look into the ASUS MB.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 07-01-2015, 09:55 AM
philip888's Avatar
Cheers
Yes I own and use the ORION.
I would not have commented otherwise.
  #16
Old 02-16-2019, 06:30 AM
jacko's Avatar
jacko jacko is offline
It's been 4 years now. Have things gotten any better with the stability? I'm thinking of Orion Studio or Orion 32+.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #17
Old 02-26-2019, 04:11 AM
stonerbox stonerbox is offline
I've had many remote sessions and email exchanges with the support/developers and they have always been great and done their very best at trying to help me resolve my issues. In my opinion they're down to earth, friendly and personal. However, it wasn't always like this though.. but things have changed for the better in the last two years.
Anyway, here's why I was going to post in the first place. I made a theme for the Orion Studio (for both legacy hardware and Revision 2017). The theme also changes how the EQ and Compressor control and view numbers (read changes down below for more info on that).
I hope it can come into good use for some of you out there, enjoy!
NEVE-R Orion 1.0 is here!
About it
After much troubleshooting of the base code and countless hours creating the enterily new UI of the control panel it is finally finished and working on both platforms. The theme is heavily inspired by a number of different Neve consoles and preamps but I've still taken some creative freedom in style. I'm fairly positive to how it turned out and it's definitely much cleaner and slicker looking than the original Orion theme.
Known issues:
Depending on the scaling of the panel the shut off LEDs (Preamp, ADAT & S/PDIF tab) may shine through even though they should be off.
Hi-RES SCREENSHOTS:
Launcher
ROUTER
MIXER
AFX
METERS
-Orion Studio Rev 2017 - Download Links-
DOWNLOAD LINKS:
NEVE-R Orion (Rev 2017) 1.0.rar
NEVE-R Orion (Rev 2017) 1.0.zip
-Orion Studio Legacy - Download Links-
DOWNLOAD LINKS:
NEVE-R Orion.zip
NEVE-R Orion.rar
Changes:
  • Edited all the needed files in order for the theme to be compatible with Orion Studio Rev 2017
  • Every section of the panel is reworked
  • Preamp, ADAT and S/PDIF has new knobs.
  • Antelope EQ and COMP has a brand new look.
  • Just like in my previous theme the Antelope EQ and COMP numbers are more accurate than the "vanilla" plugs.
  • The equalizer's gain now adjusts 1 dB each step instead of 2 dB. If you hold down shift you'll adjust 0.1 dB per step instead of 1 dB.
  • Antelope Equalizer's Frequencies can be visibly more precise (3 decimals).
  • Antelope Compressor's Ratio, Attack and Release can be adjusted more precise.
  • New icons for the launcher - They look very pixilated even though they are in high resolution, there is no way around the scaling of the launcher, sadly.
  • New Icon for the panel in Taskbar!
  • 48v, Link and Phase buttons all have individual LEDs. The LEDs were quite tricky to implement but turned out great IMO.
  • Mixer has brand new look + New sexy faders and pan, mixer pots.
  • Mixer has new Solo, Cut (mute) and Link switches that has a similar style to what can be found on the Neve VXS consoles
  • New and more minimalistic color configuration of the router.
  • Higher resolution textures for the Arrow down (preamp chooser), Solo, Mute, Stereo buttons and Reverb send / Pan potentiometers on the mixer.
  • New texture for Austria Gold 414 Mic (The mic is backwards + needs color adjustments)
  #18
Old 02-28-2019, 05:31 AM
Mine is rock solid these days except for the CP freezing sometimes but a quick reboot fixes that and I'm pretty sure the devs are working on a fix for it right now.
Antelope Orion and Dangerous Source issues. joeboisits Pro Tools 10 3 05-26-2015 02:34 PM
Pro Tools 9 latency with Antelope Orion 32 mkosacek Pro Tools 9 3 09-05-2013 07:13 PM
Antelope ORION, BURL B2 ADC, SSL MX 4-16, Focal CMS-50, Focal CMS SUB Imagine Buy & Sell 14 05-09-2013 01:42 PM
Antelope Orion - any users? Actionmusic macOS 0 02-24-2013 03:49 PM
11R EXP demo - Orion adamqlw Eleven Rack 17 05-13-2011 02:58 PM
