Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-10-2013, 10:54 PM
philip888's Avatar
philip888 philip888 is offline
Default Apogee Ensemble or Mbox 3 Pro
This may be a dumb question to some but. What are you opinions on which one would be better to get for a project studio?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 04-10-2013, 11:13 PM
Default Re: Apogee Ensemble or Mbox 3 Pro
Given the choice between the discontinued Ensemble or the MBox Pro I would pick the UAD Apollo (the likely reason the Apogee Ensemble was discontinued). Only the MBox Pro included a Pro Tools license however.
But that is just me, without knowing *any* of your needs, any comments you get back from folks run the risk of being pretty irrelevant.
Darryl
Old 04-11-2013, 05:07 AM
JoelG's Avatar
JoelG JoelG is offline
In your signature you have a MacBook and a Win7 desktop. Correct me if I'm wrong, but I think Apogee only makes Mac drivers for their newer products. That would mean you could only use it with one of your computers. That would be a deal breaker for me.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-11-2013, 08:07 AM
nst7 nst7 is offline
I agree with Darryl, that if you need the type of I/O that the Ensemble has, go for the Apollo. But as mentioned, you'll also need to buy Protools software.
Unless you already have a version you can upgrade from.
If you don't need that much I/O, the Mbox Pro is a great solution, and comes with Protools 11.
Old 04-12-2013, 09:59 AM
Kasper Kasper is offline
Consider the Symphony, if it will suit your current I/O needs, you can start with the "cheap" card and chassis.
2x6 analog, ADAT, AES and USB.
This can grow with your needs by adding cards.
It will also work as an HD interface, if you go HD down the road (if AVID doesn't kill it)
It will sound as good or better than anything else you can buy, regardless of $$, and it's a steal at $2K.
(subjectively, of course)
I believe it is Mac only though.
kasper
Old 04-12-2013, 10:04 AM
YYR123's Avatar
YYR123 YYR123 is offline
kasper
I agree with Kasper (gasp !) sonically you can count on the Symphony (just have to consider the fact you will need Preamps - which can be kind of pricy for a project)
But didn't they have problems with the drivers recently (or did they just recently fix it ? ) I don't remember
The Apollo sounds great but I don't like the idea of buying a whole new set of plugs to be able to run on the UAD cards
I would not count on Mbox3 pro considering the problems that have been posted here in the APAC
Daniel
Apogee Ensemble VS my Mbox 3 Pro moonmusic Pro Tools TDM Systems (Mac) 9 01-31-2013 01:29 PM
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2011 02:24 PM
Is anyone using the Apogee Ensemble with PT 9? lancemcv macOS 0 03-21-2011 11:24 AM
Using 003 via an Apogee Ensemble dcf16 macOS 1 01-16-2011 05:37 PM
Mbox 2, Apogee Ensemble, s/pdif problem TheSetup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2009 08:13 AM
