stock plugins for mixing
Someone advised me to have these stock plugins enabled while mixing. I would get your input as well.
1. EQ 7 band 2. Compressor 3. BF76 Peak Limiter 4. Stereo Width Is that all I need? I also have been told that I should have an Aux track as a Sub Mix routed to the main Master Fader. I've seen some mix without this. Just was curious if there is a right or wrong way to mix.
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
Re: stock plugins for mixing
It would be good for you to sit down with an experienced mixer and ask a lot of questions. Maybe you can find some demo sessions online and study the signal path.
Here is a good book: http://www.amazon.com/Mixing-Secrets.../dp/0240815807 I would say don't put any plugs in the chain until you hear a reason for needing them. Experience will tell you when you need them. Good luck
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
There's no "always" for what processing is needed, or for what order processing is needed. Sure, throw an EQ3 on each channel, but you won't always need it. Same with the compression.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
so if you don't always need an EQ or compression then what else is there? Can you mix without any plugins on the master fader?
Yeah, you most certainly can. Some people mix into a limiter, others don't. Sometimes a bus compressor, sometimes not. And sometimes an instrument doesn't need EQ. And you may find that you don't always want compression on this or that or the other. More processing doesn't mean more professional.
but what plugins do you put on the Master Fader? Now I'm really confused. I've been told to have the same plugins for every song on the master fader and to have a sub mix routed to the master fader
I can't account for what you were told... It doesn't make any sense to me.
http://duc.avid.com/showthread.php?p...16#post2271516
Using "widening" plugins as per the first post is never a good idea as it is very easy to wget a mushy unclear and precis mix. Skip that one.
Invest in yourself. Go book a few sessions with a "real" experienced engineer at a "real" studio. Ask questions, watch what he does, get instant feedback, etc. 1 real session will put you light years ahead of just asking questions online for months.
Certain stock plugins do not show up in Pro Tools 11 | ilovemusic | Windows | 3 | 10-25-2014 05:44 PM |
PT 10 Stock Plugins Missing | ukno.dino | Windows | 2 | 01-02-2012 02:52 PM |
Pro Tools 10 Stock Plugins Missing | ukno.dino | Pro Tools 10 | 0 | 12-23-2011 11:59 AM |
Mixing with Pro Tools Stock plugins only tutorial | chavernac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-08-2011 05:18 AM |
PT9 Stock Plugins | spenner | Pro Tools 9 | 20 | 01-29-2011 07:05 AM |
