Old 07-25-2012, 07:36 PM
Krzysztof Krzysztof is offline
Default Softkey assigned to Option or Shift key
Hello
I am hoping someone could enlighten me on how to assign one of the softkeys to respond as if one is holding the option or shift key on the mac keyboard. I am attempting to keep one hand over the MC Transport and the other doing mouse duty...attempting to limit the movement back to the keyboard for modifier keys. So, as an example, if i wish to make a copy of a region and drag it here or there it would be grand to be able to keep my hand on the Transport, select the 'Option" assigned softkey and drag the region with the mouse. I have attempted to accomplish assigning one of the softkeys (using the Eucon commands) to the option selection. But no option is had.
Any assistance would be appreciated.
Regards
Krzysztof
Old 07-27-2012, 05:01 AM
black_coffee black_coffee is offline
Default Re: Softkey assigned to Option or Shift key
Instead of assigning the Option EUCON command... try assigning a key command with the Option modifier. The EUCON command fires a command, but won't recognize you holding the button. The key Command way should work...
D
Old 07-28-2012, 12:20 PM
Hello
Using the 'key' functions does not work in that the 'option' command is set up to be 'option + another key'. The 'special insert' option in the commands window does not have 'option and or shift' as an available choice. Neither option nor shift seem to be selectable on their own.....so it seems. If an Avid employe could chime in on this one to clarify if this is true that would be helpful.
Regards
Krzysztof
Old 07-30-2012, 04:55 AM
Yeah... don't worry about using another key. Just select "Option" then close the window, give it a name and save.
You can even have multiple modifiers... so "SHIFT+OPTION"
D
Old 08-03-2012, 09:26 AM
This very simply does not work (at least not on my system). I've assigned the option key to any and every button on the Trasport and have seen no 'option' action.
Now i am at a loss to see what i am doing incorrectly....seems like a simple assignment process, yet there is not the expected result.
Advice.
Regards
Krzysztof
Old 04-25-2014, 08:37 PM
themightymikep themightymikep is offline
Has anyone figured this out? I'm having the same problem. When I assign any of the modifier keys (option, or shift, or whatever) to the soft keys, it doesn't do anything.
So for example, I'd like to be able to hold down a soft key and have it function as a command key, so that I can select fader 1 on my Artist Mix, hold down the soft key that's functioning as a command key, and then select fader 5 on my Artist Mix and have both tracks remain selected. I've tried reassigning the soft keys and I just can't get this to work.
Old 04-25-2014, 10:53 PM
Audioartist Audioartist is offline
Are you using the modifier keys in the eucon commands tab?
Edit...
Ok, you obviously did.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 04-26-2014, 11:25 AM
Yeah I did do that. Is this working for other people? I'm trying to find out if this is a problem with my particular setup or if this type of command just isn't supported...
I'm running Mavericks 10.9.2 and Eucon 3.1, btw.
Old 04-26-2014, 01:37 PM
robertg robertg is offline
It's not supported. Euphonix support told me that a few years ago
Old 04-26-2014, 07:05 PM
Wow that's really ridiculous! Thanks for the info though, I was going to drive myself crazy trying to figure that out.
Does anyone have any good workarounds for doing things like selecting multiple tracks using only the Mix and/or Transport, without using a computer keyboard? Seems like having to use the computer keyboard at the same time as I use the control surface defeats the whole purpose!
EQ3 control+shift click option for band pass broke crizdee Pro Tools TDM Systems (Mac) 4 11-11-2015 01:32 AM
shift+option? question BASIC87 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2002 10:23 PM
Option, Shift and Command key shortcuts sidereal-studios Pro Tools TDM Systems (Mac) 3 01-09-2002 10:29 AM
shift tracks/regions option in 4.3? inscapesound Pro Tools TDM Systems (Mac) 1 12-16-1999 10:44 AM
shift region option in 4.3? inscapesound Pro Tools TDM Systems (Mac) 0 12-16-1999 09:39 AM
