Old 09-26-2009, 03:48 AM
tsvisser tsvisser is offline
Default 003 powers up with all LEDs lit and no control surface function
Hello, just signed up to the forums to ask this question before I ship my unit off to CA for repair. A couple of weeks ago, I powered up my 003 and the following happens...
1) character display energizes
2) faders go up
3) faders go down
4) ALL LEDs light up (not normal)
5) ALL LEDs turn off
6) ALL LEDs light up again
My headphone 1 and 2 outputs work fine, the main output does not. I only use the ADAT I/O on my unit and that seems to work fine and PT LE works normally, except I have zero control surface functionality from my 003 as that all seems to be completely locked up. Ever since this happened the first time, it boots up every time exactly like this. I tried the firmware reset sequence with the AUX7/8 + mute keypress during startup, but the unit seems to completely ignore that.
I figure this is some sort of hardware issue that is going to require me to ship it off to be repaired, but just thought I would ask if anyone has any insight to this problem, and if so, if there is possibly a solution that I can implement myself without having to ship the unit.
Thanks so much in advance,
Tom
Control 24: Preamps not working and Peak leds are lit at all times andreconde ICON & C|24 2 11-07-2014 03:37 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Control 24 automation LEDs reversed JNS ICON & C|24 0 03-27-2010 12:00 AM
Help with Control 24 Issue of Flashing LEDS and Clicking Sound ekatsuleres ICON & C|24 5 08-08-2009 02:13 PM
Flickering LEDs on Profile Surface vlepore VENUE Live Sound Systems 1 12-08-2008 02:37 PM
