Old 06-03-2015, 08:49 AM
Veiko Veiko is offline
Default Tech support needed - downgraded my Eleven Rack
I hope someone from Avid will see this post!
My Eleven Rack wouldn't start properly, so I decided to try to run the firmware upgrade again. The 2.0.1 updater complained about the number of activations so I thought I'd try the 1.0.3 updater just to check if the hardware is ok.
Got it working again, but I'd like to get the expansion pack back. Avid, please send me a pm. Your email support directed me here.
Old 06-03-2015, 09:00 AM
Benoni's Avatar
Benoni Benoni is offline
Default
Is this the same computer you used originally to install the ERXP? If so, it should work as long as the hidden files are still there.
If you upgraded OS, or are using a different computer then the only thing to do it contact Avid and have them reset your SN and ID or give you a new one.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-03-2015, 11:23 AM
Default
Thanks for your reply Benoni!
Unfortunately I reinstalled Windows on the computer I ran the upgrade on, so I think the necessary files are missing
Old 06-03-2015, 03:49 PM
Benoni's Avatar
Default
Yep, you will need new codes then or have them reset if they can still do that.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-03-2015, 08:29 PM
jeffro's Avatar
jeffro jeffro is offline
Default
Looks like the original agent escalated your case, so please watch for a response to that (check your inbox as well as spam/junk folders).
(And thanks Benoni for your assistance!)
linkedin
Old 06-04-2015, 08:45 AM
Default
Thanks Jeffro, you're the best!
I got an email, but the link in it seems to be broken unfortunately. I replied to the email as well. Could you please check that for me?
Old 06-04-2015, 08:55 AM
jeffro's Avatar
Default
Checked the link and it's working for me - should take you right to the page to enter the code. Try signing into your Avid account then click Avid Software Activation and Download.
linkedin
Old 06-04-2015, 09:01 AM
Default
Thank you so much Jeffro, got it working now! :)
Accidentally downgraded Eleven Rack dan126 Eleven Rack 11 01-08-2015 01:21 AM
Eleven Rack- No sound on Startup- Help Needed MJFrench Eleven Rack 13 01-02-2012 03:27 PM
Tech Support help needed: PT 7.3.1 weirdness - PLEASE READ LoL Productions snc Pro Tools TDM Systems (Mac) 7 05-23-2007 03:49 AM
Digi! Tech Support Needed, Will You Respond. William.E.Lemuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-19-2002 09:07 AM
