Old 11-10-2020, 11:50 AM
Brandonx1 Brandonx1 is offline
Default Re: Best Atmos Panning System
What Neyrinck is doing with only edit packs is insane looking. I kind of what to try that. Motorized joysticks? What???
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-10-2020, 11:59 AM
Starcrash Starcrash is offline
As primarily a sound editor, my ideal control surface would be a fader, a joystick panner (with height), and a handful of programmable buttons. Typically I reach for the Digi joystick way more than the Artist Mix faders. If only it was Eucon and I didn't have to click the tiny little Output Window button to attention the panner, I would be so happy.
Pascal Garneau | IMDb
Old 11-11-2020, 07:21 AM
I mostly use an S6 but have a few s3's deployed. If you set your controller to attn pan on track selection, does the joystick attn as well? I don't have a midi joystick to test with.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 11-13-2020, 12:02 PM
Unfortunately, no, and I can't understand why it wouldn't. Maybe there is some combo of preferences in EuControl that can make this happen? I just tried tinkering around with it and I can't get the panner attention to switch to the selected track.
Edit: I guess it's because the Eucon controller doesn't talk to the midi panner. The midi panner sticks to the track it was assigned to until you press the little Output Window button thingy.
Old 11-13-2020, 03:02 PM
Ryan Young's Avatar
Ryan Young Ryan Young is online now
When using the surround panner, I have to click the mini-fader in the Output Window button (track I/o) for it to activate. Much better than infinitely pressing "Next Track" or "Prev Track". Stereo pans, I just use the S3.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 11-13-2020, 03:13 PM
Yes, exactly. I have a Keyboard Maestro macro that presses that little button for me on the track I have selected. It's still baffling that such a basic thing isn't automatic.
Old 11-13-2020, 03:54 PM
I'm sure it's automatic if you buy a joystick module.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 11-13-2020, 04:12 PM
Ryan Young's Avatar
Did a little searching and found this script that handles exactly that. Thanks! This is so much easier now.
Link
tell application "System Events"
if exists (process "Pro Tools") then
tell process "Pro Tools"
tell (1st window whose title contains "Edit: ")
set selectedTrack to title of button of UI element 2 of (1st row of table "Track List" whose selected is true)
set formattedString to text of selectedTrack as string
set AppleScript's text item delimiters to "Selected. "
set theTextItems to every text item of formattedString
set AppleScript's text item delimiters to ""
set formattedString to theTextItems as string
click button "Output Window button" of group "Audio IO" of group formattedString
end tell
end tell
end if
end tell
-Ryan Young
Additional Systems
Old 11-17-2020, 07:26 PM
lucienpalmer lucienpalmer is offline
I put it off for a while, but finally got the S6 joystick module a year and a half ago. Really glad I did; especially for Atmos panning- the second joystick does hight at the same time the first is doing X/Y.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
HTML code is On
Atmos slave > bed panning bug? reichman Post - Surround - Video 1 03-21-2019 11:37 AM
Looking to spec out an Atmos system... ScottyD Post - Surround - Video 5 06-07-2018 10:05 AM
12.8.1 - Panning Bug on my System bleachbro Pro Tools 12 14 12-19-2017 10:29 AM
System 5 Atmos support Tom Graham System 5 1 06-01-2014 03:56 AM
System-5 Minimal Configuration for Atmos iponxonik System 5 1 10-18-2013 07:43 AM
