Old 09-29-2018, 06:08 PM
rhumphries rhumphries is offline
Default Dyn3 De-Esser bug
I've noticed that the Dyn3 De-Esser will apply gain reduction above a certain threshold even if the range is set to 0dB.
For example: I've created a file with 8k tone at -20dB. Playing it through the Dyn3 De-esser with the range set to 0dB, I'm still seeing 4.6dB of gain reduction. the amount of gain reduction remains constant as I reduce the gain of the clip down, until I pass a threshold which seems to be around -36.5dB
Bug or Feature? I'd call it a bug.
File Type: png Screen Shot 2018-09-29 at 8.52.15 PM.png (58.6 KB, 0 views)
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
HTML code is On
Dyn3 Compressor/Limiter Q DAPianist AAX Plug-ins 12 05-16-2013 05:01 AM
Vox thru 11R...no parametric eq or dyn3 compressor? drake24 Eleven Rack 2 12-18-2012 11:57 AM
Bug in EQ3 and DYN3 aax version Henrik Rosenberg macOS 10 04-15-2012 06:28 AM
Using the PT Compressor/Limiter Dyn3 Stormie Tips & Tricks 1 11-01-2007 12:36 PM
